Metabo KGS216M Slide Mitre Saw 216mm 230V
- Suitable for the home workshop
- For sawing wood, coated panels, plastic
- Achieve precision cuts with ease.
- Adjustable table extension and integrated crosscut fence
- Easy to transport
- Integrated work light for poorly lit areas
- Non slip rubber handle and two lateral handles
Axcaliber FineLine PTFE Coated HandsawFrom £12.31 £10.26 was £13.68 £11.40 Save £1.37 £1.14 -
Axminster Combination Square Metric 300mmSpecial Price £15.20 £12.67 was £17.88 £14.90 Save £2.68 £2.23 -
Axminster 7 Piece Forstner Bit SetSpecial Price £25.48 £21.23 was £29.98 £24.98 Save £4.50 £3.75 -
The Metabo KGS216M Sliding Mitre Saw is a reliable choice for home workshop use that can handle a variety of uses at good value for money.
A strong die-cast aluminium workbench and sliding function allow for wide work pieces; it is ideal for sawing wood, coated panels, and plastics with ease and precision. The saw features a freely adjustable table extension on both sides for a practical support surface and integrated crosscut fence, creating an easy-to-use work area.
Ensuring the saw is comfortable and safety is the priority, the handle features a non-slip rubber grip, as well as lateral handles for easy transport, a transport lock and a cable winder. An integrated work light is fitted for use in poorly lit areas.
All scales are visible, and the turntable allows for precise angle adjustment, making it easier to achieve precision cuts. As well as an integrated cutting depth control, handy for achieving a variety of cuts.
Supplied with 1 x 40 Tooth Carbide Saw Blade, 2 x Table Leg Extensions, Length Guide, Material Clamp Tool for Saw Blade Change, Dust Chip Collection Bag.
Registration required within 4 weeks of purchase.
Please Note: All Warranty claims are handled directly with manufacturer please refer to the warranty information supplied on registration for correct procedure. To benefit from the Metabo XXL Warranty, simply register your tool within 4 weeks of purchase. Registration is quick and easy via the Metabo app or at metabo-service.com.
Benefits
- FREE 3-year XXL warranty on all Metabo tools
- FREE 3-year warranty on all battery packs and chargers – including LiHD and Li-Power
- No limitation on charging cycles for battery packs
- Peace of mind with extended coverage
Warranty claims outside of the UK may be subject to local service conditions. If a tool must be returned to the UK, all postage costs must be arranged and paid by the customer.
Axminster Tools cannot register a Metabo tool on a customer's behalf.
For more information and full terms and conditions, please visit the Warranty & Service section of the Metabo website.
| Bevel Angle Range | 47° - 0 - 2° |
| Blade Diameter | 216 mm |
| Blade RPM | 3,750 rpm |
| Bore Size | 30 mm |
| Corded or Cordless | Corded |
| Dust Collection | Dust Bag Supplied |
| EAN Barcode | 4007430256591 |
| Electric Brake | Standard Feature |
| Manufacturer Part Number | MPTKGS216M |
| Max Crosscut @ 0º W x H | 305 mm x 65 mm |
| Max Mitre Cut @ 45º W x H | 205 mm x 36mm |
| Mitre Angle Range | 45° - 0 - 45° |
| Model | KGS216M |
| Motor Power | 1,500 W |
| Nett Weight | 13.5KG |
| Overall L x W x H | 34cm X 81cm X 18cm |
| Plug Fitted | UK 3 pin plug |
| Rating | Home Workshop |
| Sound Power Level LwA [Uncertainty K] | 104 dB(A) [3.0 dB] |
| Sound Pressure Level LpA [Uncertainty K] | 97 dB(A) [3.0 dB] |
| Voltage | 230 V |
- Standard Delivery* - Free
