Perform Replaceable Tip Turning Tool Set (3pc)
113575
From £49.98 £41.65
  5. Half Star
7 Reviews
In Stock - Ready to dispatch
Delivery Premium
Next Day Delivery from £8*.
Order within for delivery by Tuesday 15th Sep
  • Replaceable TCT tips stay sharp longer
  • Three cutters for a range of turning tasks
  • No sharpening - just rotate or replace tips
  • Comfortable beech handles for easy grip
  • Ideal for beginners and smaller projects
Durable, precise and easy to turn!
With no bevels to master and no sharpening required, this replaceable tip turning tool set is the perfect fuss-free choice for beginners.
Durable and sharp
Durable and sharp
Designed with replaceable tungsten carbide tips, these tools offer extended life and maintain sharpness longer than traditional high speed steel alternatives.
Easy to control
Easy to control
Simply position the tool parallel to the floor on the tool rest, then move it smoothly along for precise control.
Three cutter profiles included
Three cutter profiles included…
The set includes; 11mm square cutter, 23mm round cutter and 10 x 28mm diamond shaped cutter for a range of different turning applications.
Simple maintenance
Simple maintenance
When the cutting edge dulls, simply rotate or replace the tip and you’re good to go again, there is no need to sharpen.
The Perform Replaceable Tip Turning Tool Set is a an ideal choice for those who are beginner turners, or those seeking durability and convenience. Each tool measures 330mm in overall length, providing a balanced feel that supports both precision and control during turning tasks. Designed with replaceable tungsten carbide tips (TCT), these tools offer extended life and maintain sharpness longer than traditional high-speed steel alternatives.
The set includes three cutter profiles to suit a range of turning applications: an 11mm square cutter for roughing and removing square stock, a 12mm round cutter ideal for curves and contours like the inside of a bowl, and a 10 x 28mm diamond-shaped cutter suited for fine detail work, tight corners and creating beads. The replaceable tip design simplifies maintenance - when the cutting edge dulls, simply rotate or replace the tip and you're good to go again; there is no need to sharpen. Easy to control, these tools sit parallel to the floor on the tool rest. Simply move across the rest to use.
The handles are made of smooth beech for a comfortable fit.
This set is well-suited for turners who are beginning their woodturning journey and makes an ideal accessory for the Perform PD240WL Woodturning Lathe. They are suited to smaller projects.
Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBirthday CakeA birthday cake with a candleBritish MadeBritish Made logoBulk BuysA star with lots of pointsBusiness ServicesA building with a door at the frontCatalogueAxminster Tools CatalogueCategoriesView categoriesChristmasChristmasClick & CollectA shopping bag with a handleClockA clock face showing the timeThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsDelivery QuickA clock faceCopyCopy to the clipboardEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramiwocaPayiwocaPay payment logoLinkedInThe logo for LinkedInLocationA location markerMade in BritainMade in Britain logoMenuThree Horizontal lines stacked on top of each otherNotificationA notification bellPartnerBuy from our PartnersPay By FinanceNovuna Finance LogoPayPalPayPal payment service logoPayPalPayPal payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPound SignA pound currency sign in a circlePreviewAn eye symbolPrinterA printer, printing a piece of paperPrivatePadlockRating Star EmptyEmpty rating starFull Rating StarFull rating starRating Star HalfHalf rating starRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startRewardsAxminster Tools RewardsSettingsView SettingsSign InSign In to your accountSign OutSign Out of your accountSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStarA Star symbolStarA Star symbolStockA circle which is coloured to show the current stock levelTagA clothing label tagTeachableThe Logo for TeachableTickA tick symbolDeleteDeleteUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWhatsAppThe logo for WhatsAppWishlistA heart symbolWood OutlineWood effectYouTubeThe logo for YouTube
4.57 7
