Z-Saw Blade for Japanese Fixed Pruning Saw in Sheath - 270mm
- Easily changed, replacement blade
- Clean cutting, impulse hardened teeth, 270mm long
- Universal ground teeth for fast cutting action
- High quality Japanese steel, Ni-P plated
This replacement blade secures to the handle by a simple screw. The diamond ground teeth cut on both the pull and push stroke, producing fast and clean results. The blade has impulse hardened teeth and electro-less Ni-P plating for greater wear resistance and increased corrosion protection. The 270mm long blade is replaceable; it is 0.70mm thick with a 2.4mm pitch.
| Blade Thickness | 0.70 mm |
| EAN Barcode | 5052511094370 |
| Length of Blade | 270 mm |
| Tooth Pitch \ tpi | 2.40 mm \ 10.5 tpi |
- Standard Delivery* - £5
