Axminster Professional Tenoning Plate for AP200SM
- Special tenon plate to allow machining to the top and bottom of the work piece
- Allows up to 200mm diameter tooling to be used
- Easy and safe to use, clamps next to the mitre fence
- Also fits previous models AT200SM, WS100/30 and WS1000TA
This accessory is a simple alloy plate that lifts the workpiece above the table. This means that you can machine the top and bottom surface of the work, such as when creating a tenon. It can be mounted next to the mitre fence and clamp so as to make the machining of end grain material as safe as possible. Overall length 650mm x 120mm width.
| EAN Barcode | 5052511045860 |
| Nett Weight | 1 kg |
| Overall L x W x H | 650 mm x 120 mm x 28 mm |
- Standard Delivery* - £5
