UJK Wave Forstner Cutters
- Made in Austria
- Features Serrated ‘Wave’ cutting edge for clean cutting
- Extremely precise for both softwood and hardwood
- Drill partial holes on an edge or at an angle
- Forged from one steel billet for extraordinary strength
UJK Long Series M2 HSS Premium Brad Point Drill Bit - 8mmFrom £26.88 £22.40 -
UJK Tapered Plug Cutter - 8mmFrom £19.48 £16.23 -
UJK HSS Countersink & Premium HSS Drill Bit - 4mmFrom £15.18 £12.65
The UJK Wave Forstner Cutter is designed to deliver precision and efficiency in woodworking. The UJK Wave Forstner cutter is versatile and ideal for drilling splinter-free, true-to-size, through and blind holes, edge drillings, and slant drillings in both soft and hardwood. Made in Austria, this innovative cutter combines the best features of traditional Forstner bits with advanced cutting technology, making it an essential addition to any woodworker's toolkit.
One of the standout features of the UJK Wave Forstner Cutter is its serrated 'Wave' edge. This design generates less heat, allowing for faster cutting speeds and requiring less effort to achieve each hole. The result is extremely clean entry holes and precision drilling, even at angles.
The shank features three flats for a secure fit in a 3-jaw chuck, ensuring a positive grip and longevity. The large chip-free zones ensure perfect chip removal, while the wavy peripheral cutting edge prevents annealing of the cutting edges.
Austrian made and manufactured from a single billet and CNC ground, the UJK Wave Forstner Cutter boasts exceptional strength, accuracy, and sharpness. Thanks to its ideal cutting geometries, the UJK Wave Forstner Cutter offers easy and effortless cutting, this cutter is designed to meet your needs with precision and reliability.
Diameter size up to 30mm: Shank 8mm. Diameter size from 32 mm: Shank 10 mm.
Imperial shank size: 3/8"
Please note, respiratory items cannot be accepted for a refund once the seal is broken and the item has been worn.
