Axcaliber 60 Degree Vee Groove Cutter
- 60° vee groove cutter
- Supplied with bearing to work with template
- Can be used free hand
- Sign writing, grooves in panels etc
- 1/4" shank
- Supplied in storage case
A 60° vee groove cutter, supplied with bearing to follow a template or use free hand. Uses include sign writing and producing grooves in panels. Two flute TCT cutter with 1/4" shank. Supplied in storage case.
| D = Overall Diameter | 12.7 mm (1/2") |
| EAN Barcode | 5052511063291 |
| K = Cutter Angle | 60° |
| Shank Diameter | 1/4" (6.35 mm) |
| X = Depth of Cut | 13 mm |
- Standard Delivery* - £5
