Axminster Professional AP406SS Scroll Saw - 230V
107653
From £779.98 £649.98
  5. Half Star
74 Reviews
In Stock - Ready to dispatch
Delivery Premium
Next Day Delivery from £8*.
Order within for delivery by Tuesday 6th Oct
  • Arm assembly tilts, table remains horizontal for greater control
  • Fitted with the Pegas blade clamps for easy blade changes
  • 305 x 470mm epoxy coated steel table supports larger workpieces
A high precision machine
A great tabletop machine that cuts via very fine blades allowing for very small, very high precision cuts.
Buy with confidence
Tilting arm
The saw's arm assembly is able to tilt, with pre-set angles at 90°, 45°, 30° and 22.5°. This feature ensures the table is kept flat for easier working. It also allows for greater control and more precision when cutting.
Pégas quick change blade clamps
These blade clamps make changing blades faster and easier; you’ll notice a significant difference to the performance of your scroll saw.
Epoxy coated steel table
The hard-wearing surface allows your work to move smoothly across it. At 305mm x 470mm, its supportive for larger workpieces too.
Variable speed
With between 400-1400 strokes per minute, the variable speed of the scroll saw enables you to cut various materials.
Spring loaded arm
Cut pierced projects with ease and without a fiddly set up process; the scroll saw arm is spring loaded and can be lifted, allowing you to locate the workpiece without bending the blades.
Efficient extraction and air blower
An air blower keeps the cutting line clear; vital when cutting precision work. Dust extraction takes place immediately below the blade via a 63mm outlet ensuring a clean working field.
This 406mm throat scroll saw includes an innovative design, quality construction and comes with some unique features.
The arm assembly tilts up to 45° to the right and 35° left leaving the table horizontal. With your workpiece level, you automatically have greater control and precise cuts are easier to achieve. Visibility is improved and work carried out in a natural position. The saw has a 305mm x 470mm, heavy gauge, epoxy coated plate steel table, giving plenty of support to larger workpieces. Blade changing could not be made easier. No tools required, PEGAS blade clamps are lightweight, reduce vibration and reduce stress on the machine. Changing a blade is a simple matter of operating a quick release lever. When carrying out pierced work, you can raise the upper arm to give yourself more clearance to thread the blade through the hole in the workpiece.
The variable speed control offers 400 to 1,400 strokes per minute. The control knob is conveniently placed within easy reach. Upper and lower blade guards, an air blower and work hold down are all standard. The blade actuating arms are very short, driven by a lever and rod mechanism improving control of the blade and lowering vibration. Dust extraction from immediately beneath the blade is very efficient when connected to a suitable fine dust extractor.
Using unpinned blades offers a vast choice to suit any project, you can even use 150mm lengths of 1/4" bandsaw blade for cutting thicker materials.
Look for the icon and put your trust in Axminster Tools. You’ll get our comprehensive 3-year guarantee on all Axminster Professional machines, which includes:
Year 1 – complete machinery coverage (excluding blades, abrasives, belts, filters/bags, other consumables).
Machine Classification
These products are designed for frequent and extended use in professional environments, offering the performance and durability required for trade and workshop applications, without being intended for full scale professional or continuous use. They must be maintained and serviced annually. Guarantee is void when used for industrial use or part of a production line.
Learn more
Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBirthday CakeA birthday cake with a candleBritish MadeBritish Made logoBulk BuysA star with lots of pointsBusiness ServicesA building with a door at the frontCatalogueAxminster Tools CatalogueCategoriesView categoriesChristmasChristmasClick & CollectA shopping bag with a handleClockA clock face showing the timeThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsDelivery QuickA clock faceCopyCopy to the clipboardEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramiwocaPayiwocaPay payment logoLinkedInThe logo for LinkedInLocationA location markerMade in BritainMade in Britain logoMenuThree Horizontal lines stacked on top of each otherNotificationA notification bellPartnerBuy from our PartnersPay By FinanceNovuna Finance LogoPayPalPayPal payment service logoPayPalPayPal payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPound SignA pound currency sign in a circlePreviewAn eye symbolPrinterA printer, printing a piece of paperPrivatePadlockRating Star EmptyEmpty rating starFull Rating StarFull rating starRating Star HalfHalf rating starRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startRewardsAxminster Tools RewardsSettingsView SettingsSign InSign In to your accountSign OutSign Out of your accountSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStarA Star symbolStarA Star symbolStockA circle which is coloured to show the current stock levelTagA clothing label tagTeachableThe Logo for TeachableTickA tick symbolDeleteDeleteUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWhatsAppThe logo for WhatsAppWishlistA heart symbolWood OutlineWood effectYouTubeThe logo for YouTube
4.73 74
