Axminster Twist & Fix 100mm Felt Wheel - Hard
- Hard felt for straight edge tools, razor-edge results every time
- Felt wheels produce the ultimate, mirror polished edge
- Mounts directly onto the Ultimate Edge 'Twist & Fix' arbor
- Use with honing compound
- 100mm diameter x 20mm wide, 12mm bore
Use these felt wheels to produce the ultimate, mirror polished edge. The finest edge you can get on any tool is with a strop or a felt wheel. Made from compressed wool, felt wheels have excellent resilience and are long lasting.
Hard felt is the better choice for finishing the bevel on a plane iron or bevel edge chisel. The hard face of the wheel ensures even polishing of the flat bevel without rounding over the edge.
When the wheel is dressed with a honing compound, the edge obtained is comparable to a razor blade. For best results use with Blue Steelbrite, Flexcut gold or Veritas green compound.
Each 100mm diameter x 20mm wide wheel has a 12mm bore for mounting onto the Ultimate Edge Twist & Fix arbor.
Please note that blades should always be presented to the wheel so the edge of the tool trails, i.e. the direction of rotation is away from the tool.
| EAN Barcode | 5052511109500 |
| Mop Diameter | 100 mm |
