Axminster Woodturning Thickness Calipers
- Available in large or small to cover most measuring situations
- Set contains a double ended pair for measuring wall thicknesses
- Made from stainless steel, in the UK
These turner's calipers are double ended for measuring wall thicknesses. The two ends of the calipers produce the same setting, allowing measurements to be made without removing the calipers from the work. If you are working with wet timber, these calipers are perfect as they are stainless steel, therefore corrosion resistant.
Capacities are:
Small set - 120mm
Large set - 190mm
These calipers are made in Axminster, UK.
