Axminster Set of 4 Drum Sanders
- Drum sanders for use in a pillar drill or woodturning lathe
- 4 diameters: 25.4mm (1"), 50mm (2"), 63mm (2.1/2") & 75mm (3")
- Includes 80 grit and 120 grit sleeves
Axminster 7 Piece Forstner Bit SetSpecial Price £25.48 £21.23 was £29.98 £24.98 Save £4.50 £3.75 -
JSP SpringFit™ Fold Flat Valved Respirator FFP2 (Pkt 10)Special Price £16.45 £13.71 was £18.28 £15.23 Save £1.83 £1.52 -
Axminster Combination Square Metric 300mmSpecial Price £15.20 £12.67 was £17.88 £14.90 Save £2.68 £2.23 -
Axcaliber FineLine PTFE Coated HandsawFrom £12.31 £10.26 was £13.68 £11.40 Save £1.37 £1.14 -
This set of four, 75mm long sanding drums will help you get more use out of your pillar drill or woodturning lathe. The drums are a resilient rubber fitted with an abrasive sleeve. Turning the nut located on the base of each drum, slightly expands the rubber and secures the abrasive sleeve. The diameters are: 25.4mm (1"), 50mm (2"), 63mm (2.1/2") and 75mm (3"). Partially used sleeves can be removed and kept for use at a later date. The drums come with two sets of sleeves, 80 grit and 120 grit. Replacement sleeves are readily available. Each drum has a 12.5mm shank. Maximum recommended speed 1,500rpm.
| Abrasive Backing | Cloth |
| Abrasive Material | Aluminium Oxide |
| Bobbin Height | 75 mm |
| EAN Barcode | 5052511127467 |
| Shank Diameter | 12.5 mm |
- Standard Delivery* - £5
