Axminster Drum Sander Replacement Sleeves
- Pack of 4 replacement drum sanding sleeves
- 1 each 25.4mm (1") 50mm (2"), 63mm (2.1/2") and 75mm (3")
- Available in 80 or 120 grit
Axminster Set of 4 Drum SandersSpecial Price £36.54 £30.45 was £42.98 £35.82 Save £6.44 £5.37 -
Aluminum Oxide Drum Sanding Sleeves, 75mm long. Each pack contains four sleeves, 1 each 25.4mm (1") 50mm (2"), 63mm (2.1/2") and 75mm (3"). Suitable for the Axminster Drum Sanding Set. Cloth-backed for longevity and simple changes.
| Abrasive Backing | Cloth |
| Abrasive Material | Aluminium Oxide |
| Bobbin Height | 75 mm |
