Festool TSV 60 KEBQ-Plus Plunge Saw with Scoring 230V
Spread the cost of orders up to £30,000 with iwocaPay.
We accept iwocaPay to give business customers more control when it comes to paying. iwocaPay is available for UK Limited Businesses and LLPs on orders of £150 to £30,000.
When you get to the iwocaPay checkout you'll see two choices:
- Pay Now in just a few clicks, you can scan a code to pay us straight from your bank account.
- Pay Later you'll be able to set up a payment plan with iwocaPay to split the cost with Pay in 3 (Interest Free) or Pay in 12 (3.33% Interest Rate Per 30 Days) equal monthly payments.
- Splinter-free cuts on both sides, every time
- Built-in scoring blade gives perfect results
- Clean finishes, no additional work required
- Scoring function can be switched on or off as required
- Innovative KickbackStop minimises risk of injury
- Brushless EC-TEC motor, virtually maintenance-free
- Fast and efficient cuts in timber composite materials
- FastFix spindle stop for quick and simple blade changes
- Fully compatible with Festool FS and FSK guide rails
Festool TCT Saw Blade for Laminate 168mm x 1.8 x 20mm 52TFrom £84.98 £70.82
The Festool TSV 60 K plunge-cut saw offers splinter-free cuts like you have never seen. With a built-in scoring blade preceding the main blade you are guaranteed perfect results every time. Look forward to the cleanest of finishes, on both sides of the material, from the very first cut. No additional cleaning or work required.
The TSV 60 K offers fast and efficient cuts in timber, wood based and composite materials. Perfect scoring cuts even on mitre cuts from up to 45°.
The 47mm diameter diamond tipped scoring saw blade is long lasting and gives a perfect quality cut, even in HPL materials or melamine coatings. The scoring function can be switched on or off as required.
This innovative circular saw features ai KickbackStop minimising the risk of injury and damage to the workpiece. The saw detects a kickback in the blink of an eye and stops the motor within a fraction of a second. Once the saw has been triggered, it is ready for use again straight away.
The brushless EC-TEC motor makes the TSV 60 K virtually maintenance-free and extremely powerful.
With the TSV 60 K, workshop-quality results can be replicated on site every bit as good as with a stationary machine. The FastFix spindle stop on the main saw blade makes changing the saw blade quick and simple. The TSV 60 K is fully compatible with Festool guide rails, offering 60mm cutting depth when fitted to the FSK cross cutting guide rail or FS guide rail.
Supplied with: 42 tooth TCT saw blade, 47mm diamond scoring saw blade, and Systainer SYS3 M 437.
In order to take advantage of the Festool Warranty All-Inclusive, you will need to create a MyFestool account and register your tool within 30 days of purchase.
Benefits
- Includes 36-month machine guarantee
- Full repair, free of charge
- Replaced in the event of theft*
- Original parts guaranteed
- 14-day money back*
All Warranty claims are handled directly with manufacturer please refer to the warranty information supplied on registration for correct procedure.
Warranty issues outside of the UK - Please refer to the warranty in the home country and if a tool has to be returned to UK be aware that all postage costs would need to be arranged and paid by the customer.
Axminster Tools cannot register a Festool tool on a customer's behalf.
NB: For more information and *full terms and conditions visit the Service section of the Festool website.
Find out more| Bevel Angle Range | 0° - 45° |
| Blade Diameter | 168 mm |
| Bore Size | 20 mm |
| Cable Length | 4 m |
| Corded or Cordless | Corded |
| Dust Extraction | 27 mm / 36 mm Outlet |
| EAN Barcode | 4014549373774 |
| Kerf | 1.8 mm |
| Manufacturer Part Number | 576733 |
| Max Depth of Cut @ 45º | 45 mm |
| Max Depth of Cut @ 90º | 62 mm |
| Model | TSV 60 KEBQ-Plus |
| Motor Power | 1,500 W |
| Nett Weight | 6 Kg |
| Plug Fitted | UK 3 pin plug |
| Saw Blade Speed | 3,000 - 6,800 rpm |
| Scoring Blade Diameter | 47 mm |
| Scoring Blade Speed | 16,000 - 22,000 rpm |
| Sound Power Level LwA [Uncertainty K] | 101 dB(A) [3.0 dB] |
| Sound Pressure Level LpA [Uncertainty K] | 90 dB(A) [3.0 dB] |
| Spindle Lock | Standard Feature |
| Vibration Cutting Wood [Uncertainty K] | 2.5 m/s² [1.5 m/s²] |
| Voltage | 230 V |
- Standard Delivery* - Free
