Irwin Blue Groove 4X Flat Bits
- Patented groove point cuts timber cleanly
- Drills up to 4× faster than standard bits
- Parabolic scoop improves chip removal and control
- Relief angle increased from 12° to 17°
- 152mm shank with 10% larger diameter for durability
The IRWIN® Blue Groove 4X Flat Bits are engineered for fast, clean timber cutting. Featuring a patented groove point and cutting edge, they slice through wood rather than scrape it - delivering up to four times the speed of standard flat bits.
A parabolic scoop enhances chip removal and drilling control. The relief angle has been increased from 12° to 17° for improved cutting efficiency. Each bit includes a 152mm shank that is 10% larger in diameter for added strength and durability.
