Laguna 12|16 Woodturning Lathe & Stand 230V
From £1,343.98 £1,119.98
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
  • Laguna 12|16 Lathe and Laguna Stand package
  • Lathe with heavy cast-iron bed, headstock and tailstock
  • Height adjustable Laguna stand with multi-tool shelving
  • 1-step cam handle for fast belt changes
  • Self-ejecting tailstock with long quill travel
  • Forward and reverse rotation for enhanced versatility and finish
  • 24 position spindle indexing for precise positioning
  • Spring-loaded spindle lock for secure operations
  • Soft-grip cam action levers for comfortable handling
The Laguna 12|16 Lathe is renowned for its robust construction, user friendly features and versatile capabilities, which allow a wide range of woodturning tasks to be tackled with ease. The Laguna Lathe Stand is engineered to complement the lathe perfectly, providing a height adjustable solid foundation that minimises vibrations and enhances accuracy.
Laguna Revo 12|16 Woodturning Lathe 230V
Laguna Revo 12|16 Lathe Woodturning lathe is a perfect blend of strength, precision, and user-friendly features. Engineered for precision and ease of use, this lathe combines robust construction with innovative features to deliver exceptional performance. The heavy duty heavy cast-iron bed, headstock, tailstock and banjo ensures stability and reduces vibrations, providing a smoother operation on all of your woodturning projects. Whether you're a seasoned professional or a passionate hobbyist, this lathe offers the stability, versatility, and performance you need to achieve outstanding results.
One of the standout features is the 1-step soft grip cam handle that allows for quick and easy belt changes, saving you time and effort. The self-ejecting tailstock with long quill travel enhances the diversity and usability of your woodturning tasks. Additionally, the lathe offers forward and reverse rotation, giving you versatility in your turning operations. The machine will also take an accessory ASR locking ring that will give greater safety by locking the chuck and spindle together.
The lathe's speed is monitored and automatically adjusted to maintain a constant speed, thanks to the pulse width modulation system (PWM). This system delivers a series of voltage pulses to the motor, continuously monitoring and adjusting the speed to maintain a constant rate. This ensures an impressive level of torque, even at the remarkably low speed of 50rpm, resulting in an optimal performance at all times.
The digital speed readout allows you to monitor the speed accurately. The anodized aluminium plate features ergonomically positioned controls, and the tactile, rubber-augmented knurled aluminium dial provides smooth and enjoyable variable speed control. The projected nose cone improves stability by enhancing access to the workpiece and providing wider bearing spacing. This design helps to reduce vibrations and ensures a more stable and precise operation, especially during delicate tasks.
For precise positioning, the 24-position spindle indexing is a valuable feature, enabling detailed work and repetitive tasks. The spring-loaded spindle lock ensures secure locking for safe and accurate operations. The soft-grip cam action levers provide comfortable and secure handling during adjustments, while the hardened steel leading edge tool rest offers durable support for your turning tools.
Supplied with 2MT four prong drive centre, 2MT revolving tail centre, 75mm (3") diameter faceplate, 1.8m power cable with UK 3 pin plug. Unlock your full potential with the Laguna Revo 12|16 and take your woodturning craftsmanship to unparalleled heights.
Axminster Tools offers an optional 2-year extended warranty on all Laguna machines, ensuring peace of mind and comprehensive coverage. This extended warranty must be purchased at the same time as your Laguna machine. Please see the warranty link below for more details.
Laguna Revo 12|16 Lathe Height Adjustable Stand in detail;
The Laguna Leg Stand, designed to provide a stable and ergonomic working height. This accessory transforms your benchtop lathe into a freestanding unit, offering greater flexibility in your workshop layout.
Crafted from high-quality, durable materials, the Leg Stand supports the weight and vibrations of your lathe, ensuring stability for precise and accurate results. Its adjustable feet allow you to level your lathe on uneven surfaces, enhancing stability and comfort. The stand is adjustable from 990mm to 1,143mm at the spindle centre and features ergonomic multi-tool shelving. With a net weight of 36kg, the combined weight of the Revo 12|16 mounted on the stand is 90kg.
By elevating your lathe to an optimal working height, the Leg Stand reduces strain on your back and shoulders, making long hours in the workshop more comfortable. Its sleek, sturdy construction complements the aesthetic of your Laguna Lathe and ensures long-lasting reliability.
Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBirthday CakeA birthday cake with a candleBritish MadeBritish Made logoBulk BuysA star with lots of pointsBusiness ServicesA building with a door at the frontCatalogueAxminster Tools CatalogueCategoriesView categoriesChristmasChristmasClick & CollectA shopping bag with a handleClockA clock face showing the timeThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsDelivery QuickA clock faceCopyCopy to the clipboardEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramiwocaPayiwocaPay payment logoLinkedInThe logo for LinkedInLocationA location markerMade in BritainMade in Britain logoMenuThree Horizontal lines stacked on top of each otherNotificationA notification bellPartnerBuy from our PartnersPay By FinanceNovuna Finance LogoPayPalPayPal payment service logoPayPal CreditPayPal credit payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPound SignA pound currency sign in a circlePreviewAn eye symbolPrinterA printer, printing a piece of paperPrivatePadlockRating Star EmptyEmpty rating starFull Rating StarFull rating starRating Star HalfHalf rating starRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startRewardsAxminster Tools RewardsSettingsView SettingsSign InSign In to your accountSign OutSign Out of your accountSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStarA Star symbolStarA Star symbolStockA circle which is coloured to show the current stock levelTagA clothing label tagTeachableThe Logo for TeachableTickA tick symbolDeleteDeleteUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWhatsAppThe logo for WhatsAppWishlistA heart symbolWood OutlineWood effectYouTubeThe logo for YouTube
