Lamello Tenso Pre-load Tool For P-14 & P-10
- For the easy insertion of pre-loading clips into a Tenso connector
- Fits both P-14 and P-10 size pre-loading clips
- Pre-loading lowers the force required without lessening the final power
The pre-load insertion tool aids in the correct placing of the Tenso pre-load clips into the Tenso connector. It fits both the P-14 and P-10 size pre-load clips. The Tenso’s high clamping force is one of its main features, resulting in a firm joint. However, when using several connectors at a time, considerable force is required to make the final connection. The pre-load clips lower the amount of force required to make the connection without lessening the final clamping power.
| EAN Barcode | 7640149937046 |
| Model | 145400 |
- Standard Delivery* - £5
