Makita DGA517Z Brushless Angle Grinder 125mm 18V (Body Only)
- Auto Torque Drive adjusts speed and torque for maximum efficiency
- Active Feedback Sensing Technology (AFT) prevents kickback
- Paddle switch for ease of operation and additional safety
- Auxiliary handle fits on either side of gearbox for greater control
- Electric brake quickly brings wheel to a complete stop
- Soft start reduces start-up shock, ensuring better safety
- Brushless motor, provides more power and longer runtimes
JSP Sonis® High Protection Ear Defenders SNR 37Special Price £36.78 £30.65 was £38.78 £32.32 Save £2.00 £1.67
This 18V Makita angle grinder features a brushless motor, delivering greater power and maximising battery runtimes. The Makita DGA517Z has automatic torque drive, which adjusts speed and torque depending on the load. This increased efficiency automatically gives you high speed for lighter cuts and a lower speed with more torque in heavy-duty applications.
Active Feedback Sensing Technology (AFT) prevents kickback by turning the motor off immediately should the wheel jam. A variable speed dial allows you to set the speed between 3,000 and 8,500rpm to suit various applications: cutting, grinding or sanding. XPT (eXtreme Protection Technology) protects the tool in outdoor applications or harsh environments, and gives greater protection against dust and moisture.
A rubberised soft grip minimises vibration and increases comfort and control. The paddle switch is easy to operate, and features anti-restart preventing accidental start-up if the switch is engaged when inserting a battery. The soft start eliminates any sudden jolt on start-up. An electric brake stops the disc very quickly, making this powerful machine safer to use.
The DGA517Z offers you mains performance in a cordless tool. This 125mm angle grinder scores highly for both efficiency and safety.
This is a body only machine, without batteries and charger.
The warranty period of your Makita tool may be extended to an additional 2 years subject to the following conditions:
- Makita Tools that are CE marked and (with the exceptions of Batteries, Battery Chargers, Accessories, Petrol Products, Production Tools and Air Tools and Compressors) purchased on or after 1st July 2012.
- The tool is registered by the end user within 30 days of purchase.
All Warranty claims are handled directly with manufacturer please refer to the warranty information supplied on registration for correct procedure.
For more information and to register your product visit the Makita website.
N.B. Batteries and chargers 1 year warranty. For machines purchased in the UK but then exported, the standard 2 year warranty would apply.
| Batteries Included | Body Only Tool |
| Battery Type | Li-ion |
| Battery Voltage | 18 V |
| Bore Size | 22.2 mm (7/8") |
| Corded or Cordless | Cordless |
| Disc Diameter | 125 mm |
| Disc Speed | 3,000 - 8,500 rpm |
| EAN Barcode | 0088381854047 |
| Model | DGA517Z |
| Nett Weight | 2.4 kg |
| Sound Pressure Level LpA [Uncertainty K] | 79 dB(A) [3.0 dB] |
| Spindle Thread | M14 x 2 mm |
| Vibration Grinding [Uncertainty K] | 6.0 m/s² [1.5 m/s²] |
| Vibration Sanding [Uncertainty K] | 2.5 m/s² [1.5 m/s²] |
| Warranty Length | 3 Year |
- Standard Delivery* - Free
