Mirka Vacuum Hose for Hand Sanding Blocks - 20mm x 4m
- Designed to fit Mirka hand sanding blocks
- 4m long x 20mm diameter with universal fitting
- Will fit many vacuum extractor types
This 20mm x 4 metre extraction hose is designed to fit the Mirka hand sanding blocks, although it will be suitable for other applications where a 20mm connection is present. A universal cone shaped fitting enables the fitting of the hose to many vacuum type extractors.
| EAN Barcode | 6416868961300 |
- Standard Delivery* - £5
