PROXXON LHW Long Neck Angle Grinder
- For steel, non-ferrous metals, glass, ceramics, wood and plastic
- Supplied with grinding disc, fan sander and cutting disc in neat plastic case
- Quiet and long lasting DC motor
Perfect for craft or hobby use, this tool is for cutting, rough machining, grinding, precision polishing, fine polishing and carving many materials including steel, non ferrous metals, glass, ceramics, wood and plastics. With 50mm diameter discs, it features a specially balanced, 100W powerful, quiet and long lasting DC motor. Comfortable to hold with a length of just 250mm, for long periods, a fine degree of control can be obtained when using this tool. This tool has become a firm favourite among woodturners for surface decoration on the lathe. Many accessories are available to enhance the use of this tool.
Supplied with a grinding disc (60 grit), fan sander (100 grit) and cutting disc in neat plastic case.
| Bore Size | 10 mm |
| Corded or Cordless | Corded |
| Disc Diameter | 50 mm |
| Disc Speed | 13,000 rpm |
| EAN Barcode | 4006274285477 |
| Model | LHW |
| Motor Power | 100 W |
| Nett Weight | 0.55 kg |
| Rating | Home Workshop |
| Voltage | 230 V |
- Standard Delivery* - Free
