PROXXON TG 125/E Disc Sander
- For all wood types, steel, non-ferrous metals, precious metals, plastics (also Plexiglas and glass fibre)
- Powerful and vibration-free running due to balanced DC motor
- Can be table mounted
- Housing in glass fibre reinforced casing
- Aluminium table, adjustable from +50° to -10°
- Fitted with dust extraction for connection to vacuum
The TG125/E is a precision device for fine sanding work and minor material correction. It features electronic speed control giving the range 250 to 800m/min. It is suitable for all wood types, steel, non-ferrous metals, precious metals, plastics (also Plexiglas and glass fibre). The sander is both powerful and vibration-free running thanks to balanced DC 140W motor, housed in a glass fibre reinforced polyamide case. The 140 x 98mm table is aluminium, adjustable to 50° incline downwards, 10° upwards. The 125mm diameter disc has a glued-on silicon film. This surface ensures that self-adhesive sanding discs can be removed without problems after use. Two additional quadratic silicon films ensure that used discs can be stored and reused. A suction channel allows connection to a vacuum for dust-free working. Supplied with two sanding discs of each grit: 80, 150 and 240grit. The machine can also be used vertically (clamped for safety) for sharpening tools etc.
| Abrasive Disc Diameter | 125 mm |
| Disc Speed | 250 - 800 rpm |
| EAN Barcode | 4006274270602 |
| Model | TG125/E |
| Motor Power | 140 W |
| Nett Weight | 3 kg |
| Overall L x W x H | 300 mm x 140 mm x 160mm |
| Table Size | 140 mm x 98 mm |
| Table Tilt | 10° - 0° - 50° |
| Voltage | 230 V |
- Standard Delivery* - Free
