Souber DBB Mortice Lock Fitting Jig (JIG1)
950820
From £119.98 £99.98
  5. Half Star
64 Reviews
In Stock - Ready to dispatch
Delivery Premium
Next Day Delivery from £8*.
Order within for delivery by Friday 18th Sep
  • Jig to accurately cut mortices and faceplates using your power drill
  • Fast and accurate on doors from 30mm - 55mm thick
  • Can cut door hinges and also some strike plates and electric releases
  • Self centres and clamps onto the edge of the door
  • Vertical guides, height and depth stops to ensure you do not overrun the cut area
  • Fast carbide cutters specially designed for a very clean cut
  • Supplied with 3 cutters: 19, 22 and 25.4mm diameter
  • Carry case and full instructions
  • Optional accessories available to cut deeper or wider locks
  1. Souber DBB Mortice Lock Fitting Jig (JIG1)
Total:
£136.76 £113.97
Designed to accurately mortice lock cases, the Mortice Lock Fitting Jig is fast and accurate to operate, saving you both time and money. Ideal for locksmiths, builders and avid DIYers.
Use to cut the mortice body and face plate. A plunging cutter allows quick installation of tubular latches and deadbolts.
Carbide wood cutters are designed to increase cutting speeds by up to 50% and to keep their sharpness.
Vertical, height and depth stops mean that you cannot overrun the cut area.
Can be used for concealed door closers when using the extended shaft.
This very precise drilling jig is designed specifically to guide the drilling bit to cut mortices for door locks and their faceplates. It is quick and simple to set up, self centring and locks onto the door edge securely. It really is a simple process: mark the lock length on to the door, select the width of mortice cutter that suits your lock, set the depth collar, pass the drill shaft through the jig’s guide bush, lock the jig to the door and using power from your drill, drive the carbide tipped mortice cutter into the door moving up and down; repeat process for the faceplate. This produces a very clean smooth cut and is one of the fastest most accurate ways to cut a mortice. You can also use it to cut hinges. Power drill with a 13mm chuck running at speeds 2,000 - 3,000 rpm is recommended. Supplied with 3 special carbide tipped cutters: 19, 22 and 25.4mm covering the most popular lock widths, a shaft for lock up to 100mm in depth and carry case. Other optional accessories available including offset housing kit, longer drill shafts and long drill kit to drill through the end of a door to fit electric locks accurately.
Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBirthday CakeA birthday cake with a candleBritish MadeBritish Made logoBulk BuysA star with lots of pointsBusiness ServicesA building with a door at the frontCatalogueAxminster Tools CatalogueCategoriesView categoriesChristmasChristmasClick & CollectA shopping bag with a handleClockA clock face showing the timeThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsDelivery QuickA clock faceCopyCopy to the clipboardEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramiwocaPayiwocaPay payment logoLinkedInThe logo for LinkedInLocationA location markerMade in BritainMade in Britain logoMenuThree Horizontal lines stacked on top of each otherNotificationA notification bellPartnerBuy from our PartnersPay By FinanceNovuna Finance LogoPayPalPayPal payment service logoPayPalPayPal payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPound SignA pound currency sign in a circlePreviewAn eye symbolPrinterA printer, printing a piece of paperPrivatePadlockRating Star EmptyEmpty rating starFull Rating StarFull rating starRating Star HalfHalf rating starRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startRewardsAxminster Tools RewardsSettingsView SettingsSign InSign In to your accountSign OutSign Out of your accountSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStarA Star symbolStarA Star symbolStockA circle which is coloured to show the current stock levelTagA clothing label tagTeachableThe Logo for TeachableTickA tick symbolDeleteDeleteUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWhatsAppThe logo for WhatsAppWishlistA heart symbolWood OutlineWood effectYouTubeThe logo for YouTube
4.53 64
