Axcaliber Fine Dovetail Set
- Fine Dovetail set for cutting 6.3 mm dovetails
- Suitable for the Axcaliber, Axminster and Perform dovetail jigs
- Supplied with guide bush and solid tungsten carbide dovetail cutter
- 275 mm width capacity material thickness 7 mm to 10 mm
- Super precision alloy comb
Axcaliber Cutter for Axcaliber Dovetail Jigs (19-30mm Material)From £11.18 £9.32 -
A fine dovetail set for cutting 6.3 mm dovetails with the Axcaliber dovetail jig when making small boxes, drawers or similar items. Supplied complete with a Trend style guide bush to fit many routers or the Axminster Universal Base and a solid TCT dovetail cutter. It can also be used for cutting comb joints using the same guide bush and a 5.4 mm straight cutter (666267). Width capacity 275 mm material thickness 7 mm to 10 mm.
| Dovetail Size | 6.3 mm (1/4") |
| EAN Barcode | 5052511021079 |
- Standard Delivery* - £5
