Axcaliber Ogee Kitchen Door Router Cutter Set
- Two-piece TCT ogee door set
- For cabinet and lightweight internal raised panel door production
- 76mm panel raising cutter
- Double stile and rail cutter
- Raise and lower cutter for profile and scribe joints
- Maximum timber thickness 22mm, minimum 19mm
- Overall cutter diameter 41mm
- 1/2"(12.7mm) shank
This two-piece ogee profile TCT set is used to produce cabinet and lightweight internal raised panel doors. The sets include a 76mm panel raising cutter plus a double stile and rail cutter in an ogee style. Maximum timber thickness 22mm, minimum 19mm.
Available in 1/2"(12.7mm) shank only. Must only be used in a router table.
| EAN Barcode | 5052511078011 |
| Shank Diameter | 1/2" (12.7 mm) |
- Standard Delivery* - Free
