Axminster No. 60 1/2 Block Plane
114253
From £49.98 £41.65
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
In Stock - Ready to dispatch
Delivery Premium
Next Day Delivery from £8*.
Order within for delivery by Tuesday 20th Oct
  • Low angle block plane with 13.5° blade bedding angle
  • Ideal for end grain work, trimming and fitting
  • Durable ductile iron body construction
  • Adjustable mouth for fine or coarse cuts
  • Micro-adjustable depth of cut
  • Lateral blade adjustment for precise setup
  • Precision-ground sole
  • 35mm wide, 3mm thick O1 high carbon steel blade
  • Blade hardened and tempered to HRC 63
  • Supplied with protective plane sock
Axminster No. 60 1/2 Block Plane is a versatile low angle block plane designed for trimming, fitting and general workshop use. With its blade bedded at 13.5°, it excels on end grain where a lower cutting angle produces cleaner, easier cuts, while remaining equally effective for a wide range of everyday planing tasks. Compact, comfortable to hold and easy to control, it is an indispensable plane for both bench work and site work.
Built around a robust ductile iron body, the No. 60 1/2 combines strength, durability and precision. The adjustable mouth allows you to optimise the plane for either fine finishing cuts or heavier stock removal, while the micro-adjustable depth mechanism and lateral blade adjustment provide precise blade control for producing fine, consistent shavings. Its lightweight design makes it particularly easy to manoeuvre during detailed trimming and fitting operations.
The sole measures 155mm long and is precision ground for an accurate and reliable performance. The 35mm wide, 3mm thick O1 high carbon steel blade is supplied honed and ready for final sharpening. Oil quenched, hardened and tempered to HRC 63, the blade offers excellent edge retention and durability, making it capable of tackling demanding workshop tasks with ease. Weighing approximately 800g, the plane balances stability and control in a compact format.
The Axminster range is designed to deliver dependable performance, quality craftsmanship and excellent value for woodworkers of all skill levels. Every tool is selected to meet the practical demands of modern workshops while respecting traditional woodworking principles.
One of the most useful planes in any woodworker's toolkit, the Axminster No. 60 1/2 Block Plane is ideal for end grain work, trimming, fitting and general fine-tuning of components. Suitable for hobbyists, furniture makers, joiners and professional tradespeople alike, it requires minimal preparation before use and is supplied with a protective plane sock for safe storage.
Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBirthday CakeA birthday cake with a candleBritish MadeBritish Made logoBulk BuysA star with lots of pointsBusiness ServicesA building with a door at the frontCatalogueAxminster Tools CatalogueCategoriesView categoriesChristmasChristmasClick & CollectA shopping bag with a handleClockA clock face showing the timeThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsDelivery QuickA clock faceCopyCopy to the clipboardEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramiwocaPayiwocaPay payment logoLinkedInThe logo for LinkedInLocationA location markerMade in BritainMade in Britain logoMenuThree Horizontal lines stacked on top of each otherNotificationA notification bellPartnerBuy from our PartnersPay By FinanceNovuna Finance LogoPayPalPayPal payment service logoPayPalPayPal payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPound SignA pound currency sign in a circlePreviewAn eye symbolPrinterA printer, printing a piece of paperPrivatePadlockRating Star EmptyEmpty rating starFull Rating StarFull rating starRating Star HalfHalf rating starRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startRewardsAxminster Tools RewardsSettingsView SettingsSign InSign In to your accountSign OutSign Out of your accountSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStarA Star symbolStarA Star symbolStockA circle which is coloured to show the current stock levelTagA clothing label tagTeachableThe Logo for TeachableTickA tick symbolDeleteDeleteUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWhatsAppThe logo for WhatsAppWishlistA heart symbolWood OutlineWood effectYouTubeThe logo for YouTube
