Axminster Professional SD3962B Bandsaw 415V
Spread the cost of orders up to £30,000 with iwocaPay.
We accept iwocaPay to give business customers more control when it comes to paying. iwocaPay is available for UK Limited Businesses and LLPs on orders of £150 to £30,000.
When you get to the iwocaPay checkout you'll see two choices:
- Pay Now in just a few clicks, you can scan a code to pay us straight from your bank account.
- Pay Later you'll be able to set up a payment plan with iwocaPay to split the cost with Pay in 3 (Interest Free) or Pay in 12 (3.33% Interest Rate Per 30 Days) equal monthly payments.
- 335mm depth of cut; 480mm width of cut
- Large cast iron table reduces vibration
- Powerful 3kW motor
- Hi/Low rip fence for varied cuts
- Rack and pinion table tilt mechanism for easy adjustments
- Quick release blade tensioning
- Micro switched doors for added safety
Axcaliber Ground Tooth Bandsaw Blade 3,962mm(156") x 6.3mm 6 TpiFrom £17.68 £14.73 -
Axcaliber Ground Tooth Bandsaw Blade 3,962mm(156") x 12.7mm 6 TpiFrom £19.78 £16.48 -
Axcaliber Ground Tooth Bandsaw Blade 3,962mm(156") x 19mm 3 TpiFrom £28.38 £23.65 -
Axminster Professional AP1500DE Dust Extractor 2HPFrom £539.98 £449.98 -
The Axminster Professional SD3962B Bandsaw delivers excellent reliability and precision expected in a demanding, professional workshop.
Featuring a spacious 633 x 485mm cast iron table, this bandsaw provides an impressive 335mm depth of cut and 460mm throat capacity, making it ideal for tackling large and complex projects. The table is mounted on heavy duty cast iron trunnions, offering excellent support to the work and results in smooth running timber. The balanced 500mm cast iron blade wheels and solid cast iron table minimise vibration for smoother, more consistent results when working with materials of all sizes such as large panels or thick hardwoods.
Switching from heavy rip cuts to fine, detailed work is effortless thanks to the solid Hi-Low, aluminium extruded rip fence. It's mounted on a solid steel bar, offering support for the workpiece. Quick-release blade tensioning ensures fast, simple setup and adjustment, as well as minimised downtime. The twin bearing blade guides are easy to adjust and are perfect for larger cuts and blades.
Powered by a 3-phase 3kW motor, the SD3962B bandsaw has a balanced power supply and is low in vibration, providing ample cutting force. The rack and pinion table tilt mechanism allows for precise and rapid angle adjustments, further enhancing versatility.
For safety and cleanliness, micro-switched doors automatically stop the blade within 10 seconds of opening, while twin 100mm dust extraction ports help maintain a clear, dust-free workspace.
Axminster Professional 3 Year Guarantee
Look for the icon and put your trust in Axminster Tools. You’ll get our comprehensive 3-year guarantee on all Axminster Professional machines, which includes:
Year 1 – complete machinery coverage (excluding blades, abrasives, belts, filters/bags, other consumables).
Machine Classification
These products are designed for frequent and extended use in professional environments, offering the performance and durability required for trade and workshop applications, without being intended for full scale professional or continuous use. They must be maintained and serviced annually. Guarantee is void when used for industrial use or part of a production line.
Learn more| Bandsaw Blade Length | 3,962 mm (156") |
| Bandsaw Wheel Diameter | 500 mm |
| Blade Speed | 1,500 m/min |
| Blade Width Min\Max | 6 mm to 30 mm |
| Dust Extraction Outlet | 2 x 100 mm |
| EAN Barcode | 5052511142545 |
| Max Cutting Height | 335 mm |
| Max Width of Cut | 480 mm |
| Max Width of Cut with Fence | 439 mm |
| Min Extraction Airflow Required | 1,200 m³/hr |
| Model | SD3962B |
| Nett Weight | 220 kg |
| Overall L x W x H | 940 x 803 x 1876 mm |
| Plug Fitted | UK 16A Plug |
| Power | 3.0 kW |
| Rating | Frequent Use |
| Sound Power Level LwA [Uncertainty K] | 90 dB(A) |
| Sound Pressure Level LpA [Uncertainty K] | 100 dB(A) |
| T Slot Size | 19 mm |
| Table Height | 862 mm |
| Table Size | 633 x 485 mm |
| Table Tilt | 0° - 45° |
| Voltage | 415 V |
This product is classified as a Large Delivery product and will normally be delivered within 14 working days.
This is a Bespoke Large Delivery service. Our team will contact you upon completion of your order to discuss carrier options and arrange a delivery date to suit you.
- UK Mainland - £70
- UK Remote & Offshore* - charge advised in basket
