Should they fail at any time due to a material or manufacturing defect, we will replace them free of charge. The Axminster Clamps range supports woodworking, engineering and general workshop use, delivering strength, accuracy and long‑term reliability. Lifetime Guarantee applies only to products displaying the Lifetime badge.
The jaws are robust aluminium alloy on a 20 mm x 6 mm steel bar. These die-cast jaws are capable of applying substantial pressure to the workpiece. Squeezing the handle advances the moving jaw. The spring-loaded face is slightly angled so its top touches first as the jaws close. As pressure is applied, the spring compresses to ensure even pressure distribution, even on slightly tapered surfaces. The fixed jaw is reversible to convert the clamp quickly into a spreader. The jaw faces have non-marring, glue-resistant pads and the clutch operates with a simple release. All sizes – 160Kg max clamping pressure.
Should they fail at any time due to a material or manufacturing defect, we will replace them free of charge. This guarantee does not cover damage caused by misuse, modification or over‑clamping.
