Easy Wood Tools Mini Easy Hollowing™ Set 3-Piece
- Set of 3 Mini Hollowers, small hollow forms are as easy as 1, 2, 3
- Carbide cutting tips keep an edge many times longer than HSS
- Rectangular section shafts improve stability and minimise chatter
- No need to sharpen; simply rotate cutter to a fresh edge
- American Maple handle with copper ferrule for strength
- Easy Wood Tools are 100% made in the USA
The Easy Wood Tools Mini Easy Hollowing™ Set 3‑Piece provides a complete solution for hollowing small vessels, boxes, and compact hollow forms, combining all three stages of the hollowing process in one set.
Including Mini Easy Hollower™ #1, #2, and #3, it allows you to move from bulk material removal through shaping to final internal refinement, all with tools designed for control on smaller workpieces.
Each tool in the set is fitted with a replaceable carbide cutter and designed to sit securely on the tool rest, making the hollowing process predictable and easy to control.
The Mini range offers more stability and cutting capability than Micro tools, while remaining compact enough for smaller projects.
Combined with the no‑sharpening system, this set makes hollowing more accessible, helping turners focus on technique rather than tool maintenance.
Working as a progressive 1‑2‑3 system, the Mini hollowers guide you through the complete hollowing workflow. Hollower #1 quickly removes the bulk of interior material, Hollower #2 refines and shapes the developing form, and Hollower #3 provides controlled reach for final internal finishing.
The tool shafts are designed to reduce chatter and maintain stability inside the vessel, even as you work deeper into the form. Used parallel to the floor at centre height, each tool sits securely on the rest, helping to minimise catches and deliver smooth, controlled cuts throughout the process.
Easy Wood Tools’ long‑lasting carbide cutters hold an edge many times longer than HSS and are suitable for dry or green wood, as well as acrylics. With no sharpening needed, maintenance is simple - when the edge dulls, just loosen the fixing screw and rotate or replace the cutter.
The shaft is engraved with the corresponding carbide cutter reference number for easy identification.
Specifications
Set includes: Mini Easy Hollower™ #1, #2, #3
Cutter type: Carbide hollowing cutters
Range: Mini (compact tools suited to small hollow forms)
System: Progressive hollowing set (bulk removal, shaping, finishing)
Handles: Hardwood with copper ferrules
Negative rake carbide cutters are available separately and are particularly effective on acrylics, polyester, and resin, helping to improve control and produce a smoother finish when hollowing delicate or dense materials.
| Chisel Blade Length | 82 mm |
| EAN Barcode | 811269021176 |
| Handle Length | 305 mm |
| Overall Length | 380 mm |
| Replacement Tip | Ci5-NR (109317) |
- Standard Delivery* - Free
