Einhell TE-BF 18 Li Belt File 18V (Body Only)
113555
From £79.98 £66.65
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
  • Online exclusive
  • Versatile belt file for grinding & deburring hard-to-reach areas
  • Two grinding arms (9mm & 13mm) for intricate & flat surface work
  • Pivoting arm (up to 90°) for flexible positioning
  • Adjustable speed control (250-1,700 m/min) for different materials
  • Tool-free sanding belt change with ergonomic Softgrip design
  • Part of the Power X-Change series of tools
  • 3 Year Einhell Warranty (registration required)
The Einhell TE-BF 18 Li-solo Power X-Change Belt File is a practical, handy tool for grinding and deburring hard-to-reach areas. The narrower 9mm grinding arm is perfect for tight spaces and for grinding very small, intricate work pieces. With the wider 13mm grinding arm, even larger, flat surfaces can be tackled. The grinding arm can be pivoted by up to 90°, which gives the flexibility to work from various positions and makes it easier to machine hard-to-reach areas.
The speed regulator allows the sanding belt speed to be adjusted between 250 and 1,700 m/min, so it can be tailored to the work piece at hand and the desired material removal rate. This means the tool can adapt to wide variety of materials. For more time-consuming work, the handy and lightweight cordless band file has a lock-on button.
The sanding belt can be changed via a tool-free, lever-operated mechanism, and the belt tracking is adjusted by a screw on the sanding arm. Thanks to its ergonomic design with Softgrip surfaces, the band file sits comfortably in the hand. The rugged motor housing has a Softgrip cover so it can be used as an auxiliary handle for easy handling. The grinding arm casing is made of solid metal.
Supplied with: 2 x Grinding Arms, 6 x Sanding Belts 457 x 9mm (P60, P80 & P120 grit), 6 x Sanding Belts 457 x 13mm (P60, P80 & P120 grit), 1 x Suction Adaptor and 1 x Storage Pouch.
Part of the Power X-Change series of tools, 3 Year Einhell Warranty, registration within 30 days required
Supplied as body only (no battery or charger).
Specifications:
Sanding Belt Speed: 1,700m/min.
Sanding Belt Length: 457mm.
Sanding Belt Width: 9mm or 13mm.
Grip Diameter: 40mm.
Suction Connection: Ø 35mm.
Weight: 1.13kg.
Warranty Einhell 3 Year Warranty on Tools & Batteries + 10 Year on Brushless Motor Warranty (Registration Required)
Einhell 3 Year Warranty on Tools and Batteries + 10 Year Brushless Motor Warranty (registration required)
To benefit from Einhell's extended warranty, you must register your product within 30 days of purchase. This includes:
  • 3-year warranty on power tools and batteries
  • 10-year warranty on brushless motors (with registration)
Registration must be completed by the original product user via the Einhell UK website. You'll need to provide:
  • Contact details and address
  • Product serial number
  • Purchase date
  • Retailer name and a copy of the invoice
If registration is not completed within 30 days, the standard 1-year warranty will apply.
For warranty issues outside of the UK, please refer to the warranty in the home country. If a tool has to be returned to UK, please be aware that all postage costs need to be arranged and paid by the customer.
Important Information
  • Warranty claims must be submitted before the expiry date and within 2 weeks of defect detection
  • Warranty exclusions apply—please see the full Warranty Conditions
  • Postage costs for returns to the UK must be covered by the customer
  • Axminster Tools cannot register Einhell tools on behalf of customers
For assistance, please contact the Einhell Service Hotline: 0151 649 1500.
Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBirthday CakeA birthday cake with a candleBritish MadeBritish Made logoBulk BuysA star with lots of pointsBusiness ServicesA building with a door at the frontCatalogueAxminster Tools CatalogueCategoriesView categoriesChristmasChristmasClick & CollectA shopping bag with a handleClockA clock face showing the timeThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsDelivery QuickA clock faceCopyCopy to the clipboardEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramiwocaPayiwocaPay payment logoLinkedInThe logo for LinkedInLocationA location markerMade in BritainMade in Britain logoMenuThree Horizontal lines stacked on top of each otherNotificationA notification bellPartnerBuy from our PartnersPay By FinanceNovuna Finance LogoPayPalPayPal payment service logoPayPalPayPal payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPound SignA pound currency sign in a circlePreviewAn eye symbolPrinterA printer, printing a piece of paperPrivatePadlockRating Star EmptyEmpty rating starFull Rating StarFull rating starRating Star HalfHalf rating starRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startRewardsAxminster Tools RewardsSettingsView SettingsSign InSign In to your accountSign OutSign Out of your accountSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStarA Star symbolStarA Star symbolStockA circle which is coloured to show the current stock levelTagA clothing label tagTeachableThe Logo for TeachableTickA tick symbolDeleteDeleteUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWhatsAppThe logo for WhatsAppWishlistA heart symbolWood OutlineWood effectYouTubeThe logo for YouTube
