Einhell TP-RO 18 Set Li BL Router Kit 18V (Body Only)
- Powerful brushless motor for increased runtime & performance
- Adjustable cutting depth with fine-tuned precision
- Tool-free spindle lock for easy bit changes
- Soft grip handle & chip shield for ergonomic, safe operation
- Includes multiple accessories & storage bag, but no battery or charger
- Part of the Power X-Change series of tools
- 3 Year Einhell Warranty (registration required)
Axminster Combination Square Metric 300mmSpecial Price £15.20 £12.67 was £17.88 £14.90 Save £2.68 £2.23 -
Axminster 7 Piece Forstner Bit SetSpecial Price £25.48 £21.23 was £29.98 £24.98 Save £4.50 £3.75 -
JSP SpringFit™ Fold Flat Valved Respirator FFP2 (Pkt 10)Special Price £16.45 £13.71 was £18.28 £15.23 Save £1.83 £1.52 -
Axcaliber FineLine PTFE Coated HandsawFrom £12.31 £10.26 was £13.68 £11.40 Save £1.37 £1.14 -
Axminster Stainless Steel Metric Rule - 300mmSpecial Price £2.95 £2.46 was £3.28 £2.73 Save £0.33 £0.27 -
The Einhell TP-RO 18 Set Li BL-Solo Power X-Change Router/Palm Router is powered by the Einhell PurePOWER brushless motor. This brushless motor offers more power and a longer running time than conventional carbon brush motors. After registering online, the brushless motor comes with a 10-year warranty. Together with a powerful motor, the variable speed control electronics can be perfectly adapted to any task in soft or hard wood.
The cutting depth can be infinitely adjusted and features an additional fine adjustment. Depth adjustment is performed with a multi-setting turret stop. The router is equipped with a precise twin-tube guide, a clamp (6mm and 8mm), and a spindle lock for easy tool changes. The LED light ensures the working area is perfectly illuminated. A plastic insert protects the surface of the workpiece.
The soft grip handle makes for ergonomic and safe working, while the chip shield protects the user against wood chips in the field of vision, and the two-handed attachment helps to keep the unit under precise control during use. The edge trimmer base also allows edges to be beveled.
Supplied with 1/4" collet sleeve, 6mm and 8mm collets, a parallel stop, compass tip, a copy sleeve and assembly tool, along with an extraction adapter for Einhell wet and dry vacuum cleaners and a handy storage bag for clean and safe transport.
Part of the Power X-Change series of tools, 3 Year Einhell Warranty, registration within 30 days required
Supplied as body only (no battery or charger).
Specifications:
Collet Diameter: 1/4", 6 & 8 mm.
Speed (Min./Max.): 10,000/30,000/min.
Lift Height Edge Router Attachment: 40mm.
Lift Height Router Attachment: 35mm.
Max. Shape Cutter: 30mm.
Suction Adaptor Diameter: 35mm.
Weight: 1.34kg.
Einhell 3 Year Warranty on Tools and Batteries + 10 Year Brushless Motor Warranty (registration required)
To benefit from Einhell's extended warranty, you must register your product within 30 days of purchase. This includes:
- 3-year warranty on power tools and batteries
- 10-year warranty on brushless motors (with registration)
Registration must be completed by the original product user via the Einhell UK website. You'll need to provide:
- Contact details and address
- Product serial number
- Purchase date
- Retailer name and a copy of the invoice
If registration is not completed within 30 days, the standard 1-year warranty will apply.
For warranty issues outside of the UK, please refer to the warranty in the home country. If a tool has to be returned to UK, please be aware that all postage costs need to be arranged and paid by the customer.
Important Information
- Warranty claims must be submitted before the expiry date and within 2 weeks of defect detection
- Warranty exclusions apply—please see the full Warranty Conditions
- Postage costs for returns to the UK must be covered by the customer
- Axminster Tools cannot register Einhell tools on behalf of customers
For assistance, please contact the Einhell Service Hotline: 0151 649 1500.
| Batteries Included | Body Only Tool |
| Battery Type | Li-ion |
| Battery Voltage | 18 V |
| Corded or Cordless | Cordless |
| Cutter Speed | 10,000 - 30,000 rpm |
| EAN Barcode | 4006825662818 |
| Model | TP-RO 18 Set Li BL Solo |
| Nett Weight | 1.34kg |
| Plunge Stroke | 35 mm |
| Sound Power Level LwA [Uncertainty K] | 91.4 dB(A) [3.0 dB] |
| Sound Pressure Level LpA [Uncertainty K] | 80.4 dB(A) [3.0 dB] |
- Standard Delivery* - Free
