Festool CTM MIDI I Dust Extractor 230V
Spread the cost of orders up to £30,000 with iwocaPay.
We accept iwocaPay to give business customers more control when it comes to paying. iwocaPay is available for UK Limited Businesses and LLPs on orders of £150 to £30,000.
When you get to the iwocaPay checkout you'll see two choices:
- Pay Now in just a few clicks, you can scan a code to pay us straight from your bank account.
- Pay Later you'll be able to set up a payment plan with iwocaPay to split the cost with Pay in 3 (Interest Free) or Pay in 12 (3.33% Interest Rate Per 30 Days) equal monthly payments.
- M Class, filters dust as fine as 0.1 mg/m³
- High performance turbine and variable suction.
- Automatic on/off with cordless tools using Bluetooth batteries
- Power tool socket with auto on/off for corded tools
- Touch control panel, easy to operate even when wearing gloves
- T-LOC SYS dock allows easy transport of other Festool tools
- Neat integral onboard hose and cable storage
- Castor wheels for greater mobility
- Smooth extraction hose improves extractor efficiency
- Dry and wet (when wet fiter fitted , not supplied)
The Festool CTM MIDI I is a compact M-class mobile extractor with high filtration standard of 99.9% hazardous dust as fine as 0.1 mg/m3. This is an updated version of the MIDI where the control panel has been standardised for all CT Series.
Dust extractors class M are suitable for vacuuming/extracting dry, non-combustible dusts, non-combustible liquids, wood dusts and hazardous dusts with STELs >0.1mg/m³.
It features variable suction and manual filter de-dusting for maximum efficiency. Hose detection automatically adjusts suction to the diameter of the hose in use. An innovative and intuitive touch control panel makes operating the controls extremely simple, even when wearing gloves. Fitted with integrated Bluetooth technology; it allows you to use the extractor in conjunction with a remote control or a Festool Bluetooth battery pack for automatic switching-on. Unique access to the main filter from the outside makes changing the filter quick, easy and tool-free.
The Power Take Off (PTO) feature is a plug socket, found on the wet and dry vacuum cleaner, that synchronises the operation of the vacuum cleaner with your power tool. So, when you switch on the power tool you are using, the vacuum will automatically switch on too.
The Festool CTM MIDI I includes 3.5m of conical 32/27mm smooth suction hose. This hose greatly improves efficiency. Reduced internal friction increases the airflow rate. The smooth outer skin means you no longer need worry about ribbed hose snagging on edges or inadvertently damaging a workpiece. A CLEANTEC bayonet fitting ensures a secure connection to Festool power tools for sanding, routing, sawing, etc.
The extractor has a flat top, providing space for tools and SYSTAINER cases. The top is T-LOC compatible; SYSTAINER cases lock and stack, for transporting of your other Festool power tools. The castor wheels are lockable. On-board storage for both the hose and power cable keeps everything neat for easy transportation.
The Festool CTM MIDI I is suited to both dry and wet applications (wet requires a wet filter, not supplied).
“M” class extractors vital when routing/sanding MDF, manmade boards or all solid woods (oak, beech etc).
The Festool CTM MIDI I comes with a smooth suction hose dia. 27/32 x 3.5 m AS/CT, Bluetooth functionality for extractor, remote switch-on for cordless tools, SELFCLEAN filter bag, hose holder, cable holder and SYS-Dock with T-LOC function.
In order to take advantage of the Festool Warranty All-Inclusive, you will need to create a MyFestool account and register your tool within 30 days of purchase.
Benefits
- Includes 36-month machine guarantee
- Full repair, free of charge
- Replaced in the event of theft*
- Original parts guaranteed
- 14-day money back*
All Warranty claims are handled directly with manufacturer please refer to the warranty information supplied on registration for correct procedure.
Warranty issues outside of the UK - Please refer to the warranty in the home country and if a tool has to be returned to UK be aware that all postage costs would need to be arranged and paid by the customer.
Axminster Tools cannot register a Festool tool on a customer's behalf.
NB: For more information and *full terms and conditions visit the Service section of the Festool website.
Find out more| Airflow Volume | 3,700 litre/min |
| Cable Length | 7.5 m |
| Corded or Cordless | Corded |
| EAN Barcode | 4014549445037 |
| Extractor Classification | M Class |
| Filter Surface Area | 3.5 m² |
| Manufacturer Part Number | 578326 |
| Max Capacity Dry | 15 litre |
| Max Capacity with Filter Bag | 12.5 litre |
| Max Power Tool Rating | 1,800 W |
| Model | Festool CTM MIDI I |
| Motor Power | 1,200 W |
| Nett Weight | 11.40 kg |
| Overall L x W x H | 472 x 322 x 495 mm |
| Sound Pressure Level LpA [Uncertainty K] | 70 dB(A) |
| Suction | 24.0 kPa |
| Voltage | 230 V |
- Standard Delivery* - Free
