Best Table Saw for a Small Workshop | A Complete Buyer’s Guide
Looking for the best table saw for a small workshop? Whether you’re building furniture, making cabinets, tackling DIY projects, or running a compact woodworking space, choosing the right table saw can dramatically improve accuracy, safety, and productivity.
The ideal table saw for a smaller workshop needs to balance footprint, cutting capacity, power, dust extraction, and value for money. Fortunately, there are several excellent options available, including models from the trusted Axminster Workshop and Perform ranges.
What is the best table saw for a small workshop?
For most hobbyist woodworkers and serious DIY users, the Axminster Workshop AW216BTS Table Saw stands out as the best all-round choice for a small workshop. Its compact footprint, precision-ground cast iron table, quiet induction motor and chassis-mounted trunnion system provide exceptional accuracy and stability without taking up excessive workshop space. The design delivers many of the benefits typically found on larger, more expensive table saws while remaining practical for garages, home workshops and smaller woodworking spaces.
Best small workshop table saws at a glance
- Best Overall: Axminster Workshop AW216BTS Table Saw
- Best Compact Option: Bosch GTS 635-216 Table Saw
- Best Budget Workshop Solution: Perform PD254TS 254mm Saw Bench 230V
- Best Upgrade for Serious Makers: Axminster Professional AP254SB Table Saw
- Best Premium Choice: Axminster Professional AP305SBD Table Saw
What makes a table saw suitable for a small workshop?
When floor space is limited, every machine needs to earn its place. The best table saws for smaller workshops typically feature:
- Compact footprints
- Integrated storage or mobile bases
- Extension tables for occasional large-panel work
- Effective dust extraction
- Accurate fences
- Enough rip capacity for furniture-making and cabinetry
A table saw that can process sheet material, hardwoods, and joinery components while remaining easy to move is often the sweet spot for home workshops.
Comparison chart:
Which table saw is right for you?
| Model | Best For | Blade Size | Footprint | Cutting Capacity | Portability | Value for Money |
| Axminster Workshop AW216BTS Table Saw 230V | Best Overall | 216mm | Small | Medium - High | Moderate | |
| Bosch GTS 635-216 216mm Table Saw | Best Compact Choice | 216mm | Small | Medium | High | |
| Perform PD254TS 254mm Saw Bench 230V | Best Budget Option | 254mm | Small - Medium | Medium | Moderate | |
| Axminster Professional AP254SB Table Saw | Best Upgrade Choice | 254mm | Medium - Large | High | Low | |
| Axminster Professional AP305SBD Table Saw | Best Premium Choice | 305mm | Large | Very High | Low |
Quick comparison of key strengths
| Model | Accuracy | Stability | Workshop Space Required | Furniture Making | DIY Projects |
| Axminster Workshop AW216BTS Table Saw 230V | |||||
| Bosch GTS 635-216 216mm Table Saw | |||||
| Perform PD254TS 254mm Saw Bench 230V | |||||
| Axminster Professional AP254SB Table Saw | |||||
Why the Axminster Workshop AW216BTS is the best overall table saw
The Axminster Workshop AW216BTS Table Saw earns the top spot because it is specifically suited to the realities of a small workshop. Rather than focusing purely on blade size or maximum cutting capacity, it prioritises the qualities that improve everyday woodworking.
Cast iron table for accuracy
The precision-ground cast iron table provides a flat, stable reference surface that minimises vibration and helps maintain accuracy over time. Workpieces slide smoothly across the table, improving control and cut quality.
Chassis-mounted trunnion design
One of the standout features is the trunnion-mounted motor and arbor assembly, bolted directly to the chassis rather than suspended from the table. This is a design normally associated with larger and more expensive saws. The result is smoother blade height and tilt adjustment, better alignment and improved long-term precision.
Compact but highly capable
Despite its workshop-friendly footprint, the AW216BTS offers a maximum rip capacity of 345mm together with extension tables that support larger workpieces when required. This makes it suitable for furniture projects, cabinetry components and general workshop use.
Quiet induction motor
The 1.1kW induction motor runs more quietly than many portable jobsite-style table saws, making it an excellent choice for home workshops and residential environments.
Dust collection above and below the blade helps keep the working area cleaner while improving visibility and reducing airborne dust.
Final thoughts...
If you're searching for the best table saw for a small workshop, the Axminster Workshop AW216BTS Table Saw is one of the strongest all-round options available. Its compact footprint, precision-ground cast iron table, quiet induction motor, and chassis-mounted trunnion system combine to deliver impressive accuracy, stability, and reliability without demanding excessive workshop space. It's an ideal choice for hobbyist woodworkers, furniture makers, keen DIY enthusiasts, and anyone looking for professional-level performance in a home workshop environment.
For woodworkers seeking a more budget-friendly solution, the Perform PD254TS 254mm Saw Bench 230V offers excellent value. With its generous 254mm blade, straightforward operation, and capable cutting performance, it's a practical choice for beginners, DIY enthusiasts, and those setting up a workshop without a significant investment.
For workshops where space is at an absolute premium, the Bosch GTS 635-216 is an excellent compact alternative. Its portable design and small footprint make it ideal for garages, garden workshops, and users who need a table saw that can be moved or stored away when not in use.
For those looking to invest in a more advanced setup, the Axminster Professional AP254SB and Axminster Professional AP305SBD provide clear upgrade paths, offering greater stability, cutting capacity, and professional-grade accuracy for furniture making, cabinetry, and joinery work.
Whether you're replacing an ageing saw, upgrading from a compact jobsite saw, or building your first woodworking workshop, choosing the right table saw will help you work more accurately, more safely, and with greater confidence on every project.
Discover more...
We hope you've enjoyed reading about the best table saws for a small workshop. While you're here, why not take a look at some of our other blogs?
