JSP Powercap Powered Respirator with Impact Visor
- Full face visor for clear vision and impact protection to EN.166.B.1
- Positive pressure powered respirator offering a cool, comfortable supply of filtered air
- Air is directed across your face and away from your airways, unlike in negative-pressure respirators
- Up to 8 hours of run time with the Li-ion battery, complete with a charge indicator
- Constant clean airflow at 160L/min eliminates breathing resistance
- Respiratory protection to EN12941:1998 + A2:2008 TH1P. Assigned Protection Factor 10 (UK classification) equivalent to an EN149
- Bump cap provides head protection to EN812
- Lightweight (680g) and well balanced for excellent comfort
- To reduce any possibility of premature motor failure/fan breaking it is imperative that the mask and filters are maintained, replaced and cleaned on a very regular basis
This lightweight, JSP Powercap Powered Respirator provides reliable protection in a single, integrated unit. Equipped with an impact-resistant visor, it delivers positive-pressure airflow that avoids the limitations of standard negative-pressure face masks. The motor supplies a steady flow of filtered air across your face at 160 L/min, ensuring consistent comfort. As you no longer need to draw air through a filter, breathing feels natural and effortless, reducing fatigue during extended use.
The air exiting around the sides and bottom of the mask is at slightly higher pressure than that outside, so forms a very effective seal. Beards are not a problem. If you wear glasses, these will not fog or mist up as you breathe out.
With the motor and filters positioned at the peak of the bump cap and the battery at the rear, the JSP Powercap Powered Respirator offers excellent balance. The outer cover of the bump cap is removable for easy washing, and its low overall weight of just 680 g ensures exceptional comfort during extended wear. The bump cap gives head protection to EN812.
The Li-Ion battery has a charge indicator so you can check your battery status, a fully charged battery can give you a run time of 8 hours. The filters are easy to inspect and replace. The unit provides respiratory protection to EN12941:1998 + A2:2008 TH1P. The clear visor gives you a wide field of vision along with impact protection to EN.166.B.1.
Supplied with an 8-hour battery, two filters, a flow-rate meter, micro USB charge lead, and complete instructions all within a strong storage box. A mains plug for the lead is not supplied. To extend the life of your respirator, we recommend the JSP Powercap Respirator Pre-Filter Pad (Pkt 10) (101850) and the JSP Powercap Respirator Peel Off Visor Overlay (Pkt 10) (101844).
Respiratory protective equipment (RPE) should not be used as the only means of control as it should complement other control measures such as a dust extraction system. Each RPE type and class is categorised by an assigned protection factor (APF). The APF is a number rating that indicates how much protection that RPE is capable of providing. For example, RPE with an APF of 10 will reduce the wearer’s exposure by at least a factor of 10 if used properly, or, to put it another way, the wearer will only breathe in one-tenth or less of the amount of substance present in the air.
Please note: To reduce any possibility of premature motor failure/fan breaking, it is imperative that the mask and filters are maintained, replaced and cleaned on a very regular basis.
When choosing respiratory protection, please ensure this is a suitable level of protection for the wood you are working with.
Please note: this unit was previously supplied branded Axminster APF10 Evolution® Powered Respirator under licence from JSP.
This is the IMPACT visor version - manufacturer code CAE602-941-100.
JSP Powercap 2 Year Guarantee (registration required)
JSP Powercap Powered Respirator with Impact Visor is guaranteed for a period of 24 months from date of purchase against mechanical or electrical defects. JSP undertakes to exchange or repair without charge, any part to be found defective within this specified period. Alternatively, and at its discretion, the Company may replace them.
Please note, as this is a Health and Safety respiratory item we cannot accept items for a refund once the seal is broken.
This guarantee is subject to: JSP Powercap Powered Respirator with Impact Visor has not been subject to misuse, accident, modification or repair.
This guarantee does not cover normal wear and tear. This guarantee does not affect your legal rights. This guarantee applies to the UK only.
To register the product, visit jspwarranty.com.
Important Information
For warranty enquiries outside of the UK: The respirator will need to be returned to the UK. Please be aware that all postage costs would need to be arranged and paid for by the customer.
| EAN Barcode | 5038428133630 |
| Protection Level | APF10 |
- Standard Delivery* - Free
