Laguna 14|BX Bandsaw 230V
From £1,869.98 £1,558.32
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
  • 10-point ceramic guides provide increased accuracy
  • Maximum cutting depth of 330mm, width 310mm with fence, 340mm without
  • Large precision ground cast iron worktable
  • Electronically / dynamically balanced top and bottom wheels
  • Quick release tension lever, for faster blade changing
  • Pyramid shaped spine, minimises frame distortion
  • Cast iron fully adjustable fence block with Hi-Low fence
  • Foot operated disc brake, almost instantaneous stop
  • Powerful 1.9kW motor, for demanding tasks
Serious cutting power
Meticulously engineered for unwavering stability and pinpoint precision
Greater cutting accuracy
1.3kW motor power and 330mm cutting depth
Ensures easy setup and precise cuts, even for deep timber re-sawing
Table insert adjustment
For simple levelling
Cast iron fence block
Fully adjustable fence block with hi-low fence
Table tilt
From -7 degrees to +45 degrees
Double windows
Allows you to check both tension and tracking while the machine is running
Quick-release blade tension lever
Allows faster blade changing
Solid cast wheels with polyurethane tyres
Provides cooler operation and longevity
Ultra-smooth worm gear and pinion
Provides simple blade guard adjustment
Axminster Tools Extended 2-Year Warranty
Choose Axminster Tools' extended warranty and enjoy the confidence of knowing your Laguna machine is backed by exceptional service and care.
Find out more
Unlock the full potential of your machine
With the extensive range of Laguna accessories
See the accessories
Experience exceptional precision and power with the Laguna 14|BX Bandsaw, a premium choice for professional joinery shops and serious home workshops. This bandsaw is designed with a robust build quality and advanced features that ensure superior cutting accuracy and ease of use. The 14|BX offers a balanced combination of outstanding build quality, large cutting capacity and innovative features, making it ideal for a wide range of woodworking tasks.
The 14|BX features a reinforced pyramid shaped spine in a one piece frame construction that incorporates the stand this further minimises frame distortion when the blade is fully tensioned, providing you with the precision you need for every cut. The ceramic blade guide system, a hallmark of Laguna bandsaws, creates 10 points of contact on the blade. Positioned above and below the table, these guides ensure easy setup and highly accurate cuts, even when re-sawing deep timber. The long-life ceramic guides offer a larger blade contact area than traditional bearing guides, resulting in more support for the blade and greater cutting accuracy. With a maximum cutting depth of 330mm and a cutting width of 310mm with fence, (340mm without) this bandsaw is perfect for handling a variety of tasks, allowing you to cut through thick materials with ease and precision.
The 14|BX is equipped with a powerful 1.9kW (2.5hp) braked motor with a foot operated disc brake system that provides ample power to handle a wide range of tasks whist stopping the blade even more quickly in case of an emergency, reducing the risk of accidents. By pressing the foot pedal firstly cuts power to the motor and secondly activates the disc brake to bring the saw to a virtually instantaneous stop.
The double viewing windows allow you to check both tension and tracking while the machine is running. Additionally, the quick-release blade tension lever makes it easy to change blades without compromising safety and means you can easily release the tension stress on the blade when not in use to help prolong blade life. The solid cast wheels are fitted with polyurethane tyres that provide cooler operation and longevity. The worm gear and pinion on the blade guard rise and fall is ultra-smooth and engineered to have minimum flex, even when fully extended. Fitted with twin 100mm dust collection outlets for easy connection to a dust extractor to help keep your workspace clean.
The fully adjustable Hi-Lo aluminium fence enhances versatility, allowing for full and precise timber support for both large and small work pieces. The fence height can be adjusted to 140mm or 12mm, providing flexibility for different cutting needs. Additionally, the table insert adjustment allows for simple levelling, and the table tilts to 45 degrees with a positive Stop at 90°. A flip plate allows reverse tilt up to 7 degrees when required, providing flexibility for a variety of cutting angles. The micro-polished cast iron table, measuring 406mm x 546mm, is mounted onto an oversized double cast iron trunnion with two locking points, ensuring a solid surface to work from. This table size provides ample workspace, making it easier to handle larger pieces of material. In the centre of the table is an anodised aluminium throat plate, with 4 adjusting screws, to ensure a perfect flush fit.
Elevate your woodworking capabilities with the Laguna 14|BX Bandsaw. Its exceptional precision, powerful performance, and versatile features make it the perfect addition to any high-end workshop. Investing in this reliable and innovative machine will allow you to achieve unparalleled accuracy and efficiency in your projects, ensuring that every cut is smooth and precise.
Supplied with Axcaliber Ground Tooth Blade 2,920mm (115") x 1/2" 6TPI.
N.B. This Machine requires a 16 amp supply and it's recommended that a C Type breaker is used, if you are unsure please contact a qualified electrician.
Axminster Tools offers an optional 2-year extended warranty on all Laguna machines, ensuring peace of mind and comprehensive coverage. This extended warranty must be purchased at the same time as your Laguna machine. Please see the warranty link below for more details.
Warranty Laguna 1 Year Warranty, Axminster Tools Extended 2 Year Available
Laguna 1-Year Warranty
The standard 1-year manufacturer's warranty for Laguna machines guarantees satisfactory quality, fitness for purpose, freedom from material defects, and compliance with UK regulations.
Enhance your peace of mind with Axminster Tools' optional 2-year extended warranty on all Laguna machines. This extended warranty, is only available for purchase at the time of purchasing your Laguna machine. It ensures comprehensive coverage for any defects in workmanship, parts, and materials for a full two years from the original invoice date. With this extended warranty, you can rest assured that any faulty part will be repaired or replaced at no cost to you, providing you with the highest level of support and protection on your investment.
Choose Axminster Tools' extended warranty and enjoy the confidence of knowing your Laguna machine is backed by exceptional service and care. Find out more
Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBirthday CakeA birthday cake with a candleBritish MadeBritish Made logoBulk BuysA star with lots of pointsBusiness ServicesA building with a door at the frontCatalogueAxminster Tools CatalogueCategoriesView categoriesChristmasChristmasClick & CollectA shopping bag with a handleClockA clock face showing the timeThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsDelivery QuickA clock faceCopyCopy to the clipboardEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramiwocaPayiwocaPay payment logoLinkedInThe logo for LinkedInLocationA location markerMade in BritainMade in Britain logoMenuThree Horizontal lines stacked on top of each otherNotificationA notification bellPartnerBuy from our PartnersPay By FinanceNovuna Finance LogoPayPalPayPal payment service logoPayPalPayPal payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPound SignA pound currency sign in a circlePreviewAn eye symbolPrinterA printer, printing a piece of paperPrivatePadlockRating Star EmptyEmpty rating starFull Rating StarFull rating starRating Star HalfHalf rating starRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startRewardsAxminster Tools RewardsSettingsView SettingsSign InSign In to your accountSign OutSign Out of your accountSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStarA Star symbolStarA Star symbolStockA circle which is coloured to show the current stock levelTagA clothing label tagTeachableThe Logo for TeachableTickA tick symbolDeleteDeleteUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWhatsAppThe logo for WhatsAppWishlistA heart symbolWood OutlineWood effectYouTubeThe logo for YouTube
