Laguna Wheel Kit-14|12, 14|BX Bandsaws & 12|16 Lathe
- Enhances the overall functionality of your workshop setup
- Designed for maximum stability and ease of use
- Features single pedal mechanism for effortless wheel engagement
- Compatible with: Laguna 14|12 and 14|BX Bandsaws and 12|16 Lathe
The Deluxe Wheel System is designed for maximum stability and ease of use. It features a single pedal mechanism that allows you to engage the wheels effortlessly. When you press the pedal, the wheels are lowered, lifting the equipment slightly off the ground, making it easy to move. Once you release the pedal, the wheels retract, and the equipment is set back down on its stable base, ensuring it remains secure and steady during use.
This system is compatible with several Laguna tools, including the Laguna 14|12 and 14|BX Bandsaws, and Laguna 12|16 Lathe. This compatibility ensures that you can easily integrate the wheel system with your existing Laguna equipment, enhancing the overall functionality and mobility of your workshop setup.
| EAN Barcode | 5052511135479 |
- Standard Delivery* - Free
