Mirka DEOS II 353CV 81 x 133mm Sander Deco Solution Kit
- Powerful and compact orbital palm sander
- Low maintenance 300W brushless motor
- LED speed indicators to easily adjust variable sanding speed
- Delivers precise and efficient performance
- 3mm orbit for fast material removal
- Exceptionally low vibration levels for increased comfort
- Integrated vibration sensor with enhanced Bluetooth technology
Mirka DEOS II 353CV is a powerful and compact orbital palm sander, slightly over 100mm tall and with an 81 x 133mm pad. It is mainly for woodwork and decorative painting, and is ideal for use on doors and windows, corners, edges and tight spaces. The sander features upgraded power compared to previous models; the body of the machines houses a 300W brushless motor for an extended service life, delivering plenty of power to finish sanding tasks quickly and efficiently.
The 353CV includes the same innovative features as the rest of the highly regard Mirka sander range. The body is very lightweight, making it easy to manoeuvre and handle. The grip is ergonomic, ensuring both comfort and complete control. There is variable speed control ranging from 5,000 - 10,000rpm, and the upgraded design makes it easy for the operator to change the speed. LED indicators are located on the speed selector, together with a separate on/off switch and lockable speed for optimum control.
Mirka DEOS II features an integrated vibration sensor with enhanced Bluetooth technology. The vibration sensor allows you to view and monitor vibration levels on a smartphone or tablet, via the myMirka app.
In combination with Mirka's Abranet abrasive and suitable vacuum extractor, the DEOS 353CV offers fast, efficient and dust-free sanding performance.
The Deco solutions kit includes:
230V DEOS 353CV palm sander
50 x Abranet® strips grit P80
50 x Abranet® strips grit P120
50 x Abranet® strips grit P180
T-LOC storage case
Registration is required within 30 days of purchase.
The Mirka 2+1 year warranty applies to Mirka sanders, dust extractors and polishers. If a problem occurs with a Mirka tool caused by a manufacturing defect material or by workmanship; Mirka will repair your tool free of charge in accordance with the warranty terms.
Registration is required within 30 days of purchase. More information can be found on the Mirka warranty website and in the warranty conditions.
For warranty issues outside of the UK, tools must be returned to the UK and carriage charges would be at the customer's own cost.
Register your product now| Corded or Cordless | Corded |
| Dust Extraction | 27 mm Outlet |
| EAN Barcode | 6416868519303 |
| Model | DEOS II 353CV |
| Motor Power | 300 W |
| Nett Weight | 0.97kg |
| No Load Speed | 5,000 - 10,000 rpm |
| Orbit Diameter | 3.0 mm |
| Pad Size | 81 mm x 133 mm |
| Plug Fitted | UK 3 pin plug |
| Sound Power Level LwA [Uncertainty K] | 80 dB(A) [3.0 dB] |
| Sound Pressure Level LpA [Uncertainty K] | 69 dB(A) [3.0 dB] |
| Vibration Sanding [Uncertainty K] | 2.6 m/s² [1.5 m/s²] |
| Voltage | 230 V |
- Standard Delivery* - Free
