Axminster Multiple Stepped Hose Adaptor
- Seven different sizes
- Simply cut sections required with a hacksaw
- Can form two or more adaptors
- External diameters: 25, 50, 63, 75, 100, 125 and 150mm
A stepped ABS hose adaptor with seven different sizes that can form perhaps two or more adaptors. Simply cut the section you require with a fine toothed saw. Diameters are 25mm, 50mm, 63mm, 75mm, 100mm, 125mm and 150mm (sizes stated are outside diameter).
| EAN Barcode | 5052511050291 |
- Standard Delivery* - £5
