Thicknessing made easy
The PD318BT Benchtop Thicknesser takes the hassle out of achieving precise timber thickness. With its generous capacity, powerful motor, and quality blades, it’s the ideal choice for DIY enthusiasts and home workshops alike.
Small and compact
The PD318BT Benchtop Thicknesser is ideal for smaller workspaces thanks to its compact size.
Impressive capacities
With a maximum thicknessing width of 318mm and a height capacity of 153mm, the thicknesser can handle most tasks with ease.
Fold down extension tables
Equipped with sturdy fold down extension tables, the PD318BT easily supports longer boards ensuring steady planing. Built in rollers let you feed heavier workpieces effortlessly.
Easy to read scale
The easy-to-read scale allows you to quickly and accurately set your desired timber thickness, meaning adjustments are simple and efficient.
Powerful motor
The high powered 1.8kW motor maintains blade speed for a consistent cut and quick stock removal.
Efficient cuts per minute
With 18,000 cuts per minute, you'll achieve a smooth, clean finish on every project in no time.
High speed steel blades
The two high speed steel blades help to achieve excellent, smooth results and can be re-sharpened so you can use repeatedly.
Safeguard your health
Connect your benchtop thicknesser to a suitable vacuum extractor via the 50mm dust port.
