Build the right UJK Workbench for you
Not sure which frame, support or worktop to choose?
Read our buyer's guide to the UJK Multifunction Workbench Mk II and find the setup that suits your space and way of working.
The UJK Multifunction Workbench Mk II is a highly adaptable, modular workbench frame developed to suit modern workshops, whether at home or in a professional environment. This updated Mark II version builds on the original design, offering enhanced durability, improved functionality and greater flexibility to support a wide range of woodworking and making tasks.
Manufactured in Britain, the Multifunction Workbench Mk II features a strong and stable frame made from high-quality birch plywood. The plywood is constructed with cross-grain layers set at right angles to one another, delivering excellent rigidity and long-term dimensional stability. An 18mm outer frame combined with a 12mm inner frame ensures the structure remains perfectly flat and true. All four sides are finished with the distinctive Heksa hex‑grip surface, providing excellent clamping grip along with resistance to moisture, weathering and common workshop chemicals. The front and rear aprons are machined with 20 x 20mm bench dog holes and an integrated T‑track on both sides, allowing fast, accurate and secure clamping and alignment.
Sitting at the heart of the UJK modular system, the Multifunction Workbench Mk II can be completed with a range of UJK worktops or bespoke Parf Guide tops and mounted on Telescopic Trestles or Sawhorses to create a strong, stable and easily portable setup. Positive location points ensure seamless integration with the UJK support system, allowing you to configure a versatile working platform that suits your space and the way you work.
The overall dimensions of the frame are 1,140mm x 750mm x 150mm, and it is certified by the Pan European Forest Council (PEFC), ensuring responsibly sourced materials.
The UJK modular system can be purchased as a workbench frame only, as a frame supplied with two UJK Telescopic Trestles, or as a frame supplied with two UJK Sawhorses. The setup is then completed by adding a UJK worktop of your choice (102537, 102538 or 109796), or a bespoke top made using the UJK Parf Guide System.
