Axcaliber Sash Bar Ovolo Cutter Set
- Make sash windows quickly and efficiently
- Profile and Scribe cutters included
- 1/4" shank
A pair of matched cutters used for the fast, accurate and efficient manufacture of sash windows using a router table set-up. The profile cutter will produce the moulding on the stiles and rails and the matching cutter produces the scribe at the ends of the rails and sash bars to fit over it. The profile cutter is 22mm diameter, 10mm radius, with a 18mm depth of cut and the scribing cutter is 25mm diameter, 10mm radius, with a 20mm depth of cut. Available in 1/4"(6.35mm) shank only.
| EAN Barcode | 5052511039890 |
| R = Radius | 10 mm |
| Shank Diameter | 1/4" (6.35 mm) |
