Axminster Heavy Duty Mobile Base - 540kg
- Helps free up space in the workshop
- Provides safe and easy mobility for heavy machines
- Two fixed wheels, two castoring wheels for easy movement
- Good solid platform for a large range of machines
- All steel construction
- Maximum total loading 540kg
- 460mm x 620mm min up to 720mm x 850mm max
In every workshop, space is at a premium. The ability to move a piece of equipment into a convenient working position or park it out of the way is a huge bonus.
Our heavy duty mobile base has two fixed wheels at the rear and features two castoring wheels at the front. It is a practical method for manoeuvring heavy machines into position safely and with ease. Once the machine is in position, screw-down feet raise the castoring front wheels off the floor, allowing the base to rest securely on the floor. The Axminster Heavy Duty Mobile Base takes the strain out of moving machinery around your workshop.
Maximum total load is 540kg and the size limits are 460mm x 620mm minimum, up to 720mm x 850mm maximum.
| EAN Barcode | 5052511102082 |
