Axminster Professional AP3600B Bandsaw 230V
Spread the cost of orders up to £30,000 with iwocaPay.
We accept iwocaPay to give business customers more control when it comes to paying. iwocaPay is available for UK Limited Businesses and LLPs on orders of £150 to £30,000.
When you get to the iwocaPay checkout you'll see two choices:
- Pay Now in just a few clicks, you can scan a code to pay us straight from your bank account.
- Pay Later you'll be able to set up a payment plan with iwocaPay to split the cost with Pay in 3 (Interest Free) or Pay in 12 (3.33% Interest Rate Per 30 Days) equal monthly payments.
- 360 mm depth of cut; 420 mm width of cut
- Large and supportive table with cast iron trunnion
- Powerful 2.5kW braked motor
- Hi/Lo easy glide rip fence
- Quick release blade tension lever
A powerful, capable machine
The AP3600B will add serious ability to your workshop and no doubt become a workhorse among your machinery.
3 Year Guarantee
Huge cutting capacity
With a generous 360mm depth and 420mm width of cut, you can handle impressive timber sizes.
Large cast iron table
The table is 485mm x 560mm cast iron with double trunnion table support. This offers maximum support for heavier pieces.
Powerful 2.5kW motor
The AP3600B has the power to match the capacity, meaning it can cut 360mm material with ease.
T-style Hi/Lo rip fence
Rigid, easy glide rip fence with two height options for accurate heavy duty ripping and close to the blade work.
Cast iron blade wheels
Achieve cleaner, smoother cuts thanks to the fully balanced blade wheels which reduce vibration and maintain blade speed.
Superior blade guides
Independent adjustable blade guide system for quick and easy set up.
Heavy duty handwheels
These durable metal handwheels will provide smooth adjustment for years to come.
Rack & pinion upper guide adjustment
Easily adjust the upper blade guide with the rack and pinion rise and fall. There is also a tension release lever for straightforward blade changes.
Co-Matic AF06 Light Duty Bandsaw Feeder 230VFrom £639.98 £533.32 -
Axminster Extraction Hose Kit - 100mm x 4mSpecial Price £63.36 £52.80 was £90.48 £75.40 Save £27.12 £22.60 -
JSP SpringFit™ Fold Flat Valved Respirator FFP2 (Pkt 10)Special Price £16.45 £13.71 was £18.28 £15.23 Save £1.83 £1.52 -
Axminster Stainless Steel Metric Rule - 300mmSpecial Price £2.95 £2.46 was £3.28 £2.73 Save £0.33 £0.27 -
Axminster Combination Square Metric 300mmSpecial Price £15.20 £12.67 was £17.88 £14.90 Save £2.68 £2.23 -
Axminster 7 Piece Forstner Bit SetSpecial Price £25.48 £21.23 was £29.98 £24.98 Save £4.50 £3.75 -
Axcaliber Ground Tooth Bandsaw BladesFrom £11.98 £9.98 was £11.98 £9.98 Save £0.00 £0.00 -
Axcaliber FineLine PTFE Coated HandsawFrom £12.31 £10.26 was £13.68 £11.40 Save £1.37 £1.14
The AP3600B is a modern and capable bandsaw, offering robust build quality alongside impressive cutting power.
With a generous 360 mm depth and 420 mm width of cut possible, it also features a large 485 mm x 560 mm cast iron table. The table is engineered with a double trunnion table support, making it ideal for supporting large pieces of timber with ease. The powerful 2.5kW motor means you can easily handle big cuts, as required in a demanding workshop.
The bandsaw is supported by a solid steel tubular frame which limits vibration. It comes supplied with a rigid T-style, easy glide Hi / Lo rip fence for highly accurate cuts. The cast iron blade wheels are fully balanced, reducing vibration further as well as reducing any fatigue from use.
You can rest assured that this machine meets all safety requirements: it features a key switch for extra safety when away from the machine, as well as an emergency stop switch. Dual dust extraction ports provide efficient methods of dust extraction to keep your workshop clean and dust free.
Set up is a breeze; premium blade guides and a quick release blade tension lever make changing or adjusting your blades quick and easy. With levelling feet, you can get your bandsaw perfectly aligned in the workshop. Heavy duty metal handwheels mean your machine will remain in service longer.
Supplied with a 3/4" x 3 TPI blade.
N.B. This Machine requires a 16amp supply and it's recommended that a C Type breaker is used, if you are unsure please contact a qualified electrician.
Axminster Professional 3 Year Guarantee
Look for the icon and put your trust in Axminster Tools. You’ll get our comprehensive 3-year guarantee on all Axminster Professional machines, which includes:
Year 1 – complete machinery coverage (excluding blades, abrasives, belts, filters/bags, other consumables).
Machine Classifcation
These products are designed for frequent and extended use in professional environments, offering the performance and durability required for trade and workshop applications, without being intended for full scale professional or continuous use. They must be maintained and serviced annually. Guarantee is void when used for industrial use or part of a production line.
Learn more| Bandsaw Blade Length | 3,600 mm (141.3/4") |
| Bandsaw Wheel Diameter | 430 mm |
| Blade Speed | 870 m/min |
| Blade Width Min\Max | 6 mm to 25 mm |
| Dust Extraction Outlet | 100 mm & 63 mm |
| EAN Barcode | 5052511132379 |
| Max Cutting Height | 360 mm |
| Max Width of Cut | 420 mm |
| Max Width of Cut with Fence | 335 mm |
| Min Extraction Airflow Required | 1,200 m³/hr |
| Nett Weight | 158 kg |
| Overall L x W x H | 970 mm x 960 mm x 1,915 mm |
| Plug Fitted | UK 16A Plug |
| Power | 2.5 kW |
| Rating | Frequent Use |
| Sound Power Level LwA [Uncertainty K] | 76.2 dB(A) |
| Sound Pressure Level LpA [Uncertainty K] | 72.3 dB(A) |
| T Slot Size | 19 mm |
| Table Height | 895 mm |
| Table Size | 485 mm x 560 mm |
| Table Tilt | 0° - 45° |
| Voltage | 230 V |
- UK Mainland - £70
- UK Remote & Offshore* - charge advised in basket
