KNIPEX CoBolt® Bolt Cutters Multi-Component Grip with Spring 200 mm
- Online exclusive
- Lever action mechanism for low friction
- Cutting performance 20 times higher than hand force
- Ideal for piano wire, bolts, nails, rivets, and screws
- Induction-hardened cutting edges for durability
- Edge hardness approximately 64 HRC
- Exceptional cutting with minimal effort
Experience exceptional cutting performance with the KNIPEX CoBolt® Compact Bolt Cutters featuring a multi-component grip with a return spring. These cutters feature a lever action mechanism that guarantees an extremely favourable lever ratio with low friction, resulting in cutting performance that is 20 times higher than the hand force applied, requiring 60% less effort. Ideal for cutting piano wire, soft solid wire, bolts, nails, rivets, and screws, these cutters are induction-hardened and equipped with precision cutting edges. The edge hardness is approximately 64 HRC, providing added strength and durability. The lever action ensures exceptional cutting performance with minimal physical effort.
| EAN Barcode | 4003773067078 |
