Kreg Pocket-Hole Jig XL
114944
From £55.98 £46.65
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
Low Stock - Ready to dispatch
Delivery Premium
Next Day Delivery from £8*.
Order within for delivery by Tuesday 6th Oct
  • Creates extra-large pocket holes for stronger joints
  • Ideal for 2x4 and 4x4 timber construction
  • Hardened steel drill guides
  • Dual drill guides separate for flexible spacing
  • GripMaxxâ„¢ anti-slip base
  • Compatible with Kreg XL Pocket-Hole Screws
  • Suitable for material up to 90 x 90mm
Kreg Pocket-Hole Jig XL is designed for creating extra-large pocket holes and exceptionally strong joints in large timber sections. Ideal for 2x4 and 4x4 construction, this heavy-duty jig pairs with Kreg XL Pocket-Hole Screws to deliver joints with outstanding holding power for structural woodworking, outdoor projects and large furniture builds.
The jig features hardened steel drill guides that position the XL stepped drill bit at the optimum angle for strong, accurate pocket holes. Dual drill guides are spaced perfectly for common framing timbers but can be separated for greater flexibility when working with larger stock. GripMaxxâ„¢ material on the underside helps keep the jig firmly in place during drilling, while the included universal clamping adapter allows it to be secured using Kreg clamps and many other clamp brands. Simple drill bit setup and built-in material adjustment make the system quick and easy to use.
Constructed with durable hardened steel drill guides, the Pocket-Hole Jig XL is built for long-term accuracy and repeated workshop use. It can be used on timber sections up to 90 x 90mm, making it ideal for heavy-duty joinery applications where standard pocket-hole systems may not provide sufficient strength.
Kreg is known for innovative woodworking solutions that help makers achieve stronger joints, cleaner finishes and more professional results with less effort.
Perfect for pergolas, workbenches, outdoor furniture, timber framing projects and other large-scale woodworking tasks, the Pocket-Hole Jig XL is supplied with an XL stepped drill bit, depth stop with viewing window, XL screwdriver bit and universal clamping adapter.
Compatible with Kreg XL Pocket-Hole Screws and the Kreg Pocket-Hole Jig XL Drill Bit.
Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBirthday CakeA birthday cake with a candleBritish MadeBritish Made logoBulk BuysA star with lots of pointsBusiness ServicesA building with a door at the frontCatalogueAxminster Tools CatalogueCategoriesView categoriesChristmasChristmasClick & CollectA shopping bag with a handleClockA clock face showing the timeThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsDelivery QuickA clock faceCopyCopy to the clipboardEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramiwocaPayiwocaPay payment logoLinkedInThe logo for LinkedInLocationA location markerMade in BritainMade in Britain logoMenuThree Horizontal lines stacked on top of each otherNotificationA notification bellPartnerBuy from our PartnersPay By FinanceNovuna Finance LogoPayPalPayPal payment service logoPayPalPayPal payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPound SignA pound currency sign in a circlePreviewAn eye symbolPrinterA printer, printing a piece of paperPrivatePadlockRating Star EmptyEmpty rating starFull Rating StarFull rating starRating Star HalfHalf rating starRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startRewardsAxminster Tools RewardsSettingsView SettingsSign InSign In to your accountSign OutSign Out of your accountSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStarA Star symbolStarA Star symbolStockA circle which is coloured to show the current stock levelTagA clothing label tagTeachableThe Logo for TeachableTickA tick symbolDeleteDeleteUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWhatsAppThe logo for WhatsAppWishlistA heart symbolWood OutlineWood effectYouTubeThe logo for YouTube
